Question about Konica Minolta magicolor 2430 DL Laser Printer
The ink isn't setting
Whenever a page is printed out the ink on the left hand side of the page dose not stay on the page. So whenever you touch the ink on the left side of the paper it smudges to the point you cant read it.
  • 1,219 Answers
It is fixing problem, the fixing roller is damadged, or pressure roller bushing is broken, you need to replace the fixing unit.
Posted on Apr 30, 2010
Whenever i print a document, y get white lines at best, sometimes i get nothing, but in the test page i always get an awsome quality. whats going on?
1. Get a damp paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Snap the cartridges back into the printer.
Good Luck!!!!!
Sep 25, 2011 | Office Equipment & Supplies
The printer sounds like it is printing but the page comes out blank.
Problem Blank Pages; Blank Print Out Solution
Symptom
When printing from the S or Pro Series printers, you may encounter blank pages being printed.
Solution
To rectify this issue, please follow the troubleshooting steps below:
Action Image 1
While on the main screen of the printer, open the cover.
  • If the printhead stays to the left, go to Step 2.
  • If the printhead comes to the center, do not continue troubleshooting because the printhead is faulty.
ss_mainscreen.jpg 2
Place the printer into "Replace Printhead" mode using the Maintenance menu. To access this mode, follow the steps below:
  • Touch Screen Printers:
    • Tap on the Ink Levels icon.
    • Tap on More Options.
    • Select Replace Printhead.
  • LCD Screen Printers:
    • Press the Setup button and use the arrow buttons.
    • Select Maintenance.
... 3
Open the covers and look into the printer on the left-hand side where the cartridges are inserted into the printhead - aWICKING PAD is located there.
  • If this PAD is BLACK (as seen in the right-hand image; click it for larger view), then the printer has successfully gotten ink into and through the printhead.
  • If the PAD is WHITE, then the printer has not been able to make the ink flow through the printhead. Go to Step4.
pad.jpg 4 Seat the printhead again. Unpower the printer and connect it again. Open the cover and reseat all four tanks. Press firmly on the rear of each tank and make sure all four snap in tight. ... 5
Insert plain paper and run Deep Clean.
    • Select Deep Clean Printhead.
    • Press the Setup button.
If you cannot get all four inks to lay clean, identify which one, if any of them, is failing.
  • If there is just some ink on the page - run the Deep Clean again.
  • If there is no ink at all, then the printhead is faulty.
Jul 17, 2011 | Lexmark Prospect Pro205 Wireless...
Error code 5200
- unplug the power n usb cord
- keep the headprint inside the craddle
- try to move the headprint into full right-corner(headprint
cleaningside)by moving-left the craddle belt until u heard
some "snapp" sound
- plug the powercord again
- if u heard "cleaning progress" then u r printer going to respond
- try to print 'printer test page' or 'nozzle check'
- if it succeed, try to print some 5-10 pages continuous
the dreaded 'Error 5200'. According to PrintX, the error is caused by printer head overheating and I think thats correct because whenever I touch the "Do not touch/ hands off" part of the print head, I feel some SCALDING heat.
TIPS. 1. Plug out your printer when not in use. Never let it undergo standby mode. Plug it in ONLY when it is needed. The reason behind this is that your printer only needs VERY little amount of electricity (around 5-24 V at 0.2-0.55 A, stepped down by its built-in transformer) and after a length of time, excessive heat accumulates not only in the heat board but also in the sensitive print head. Unlike how our computers heat up, the heat in the print head is SCALDING!. This is based from experience. Try touching your printer's too.
IP1500 error5200
1. Set "ink counter reset" (If you chage cartridge new one or refill).
2. Set "low ink warning setting" as default.
3. Unplug power and USB cable.
4. Waiting 10 min.
5. pluging in power and USB cable.
Please make 1 step and check result.
Good luck
http://www.cyber-ink.com/member-canon.html
Handy link above.
http://www.nodevice.com/manual/newmans/1164257352iP6600Dsmpdf/get13866.html
Service manual link above get this it is invaluable for repair.
http://www.nodevice.com/manual/Canon/page15.html
Link for SM, in case link above is dead.
Apr 09, 2010 | Canon PIXMA iP6700D InkJet Photo Printer
Every time I print,the right hand side of the page
Epson inkjet printer or Epson laser printer?
If inkjet, then run the Epson software to "clean" the print-heads.
If laser, then the "fuser" (which uses heat to bond the ink to the paper) is not working -- touch the paper, and see if the left side is warm while the right side is cool.
Nov 01, 2009 | Epson Office Equipment & Supplies
Whenever I try to print out a word document only half of it ever comes out ( the left hand side ) but the right hand side is completely blank. Is this likely to indicate a printer problem or the way the...
Try to change text orientation form portrait to landscape.If the black is on the same side of the text problem is on the document, if black is on the same side of the paper problem is on the printer.
Sep 25, 2008 | Office Equipment & Supplies
Canon Pixma Ip4200 Ink Smudges
1. Do you use refilled or genuine Canon cartridges?
2. Anyway, try to clean the printheads, because they seam to leak.
3. Verify if the cartridges are correct alignet (in maintenance software you have soewhere an "align cartridges" function
Feb 11, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Faded left hand copies
Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
Jan 23, 2008 | Konica Minolta magicolor 2400 Laser...
Hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Nov 01, 2007 | HP LaserJet 2420 Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
89 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
