Question about Avaya 5400 Series 5410 Phone
Ringing symbol on line b
There seems to be an issue with this phone that wont go away. The ringing symbol seems to be stuck on line b therefore the line is constantly jammed.
Noone can call in. When they do it goes straight to voicemail. When the phone is replaced
When you are talking to someone, and you hang up the handset, does it actually disconnect the caller?
Posted on May 05, 2010
When i call certain contacts it rings 3 times then goes to voicemail
Once you call people on there mobile phone others pre set there own ringing therefore u will find that some calls have longer dialling tones and others may have shorter
It all depends on the individuals mobile ringing settings
U can control ur own via applying a ringing that's continuous with minimal pauses but can't change other people's ringing length unless u have access to there phone
Feb 02, 2015 | Video Game Consoles & Games
Hi would like to know how to set an extension not to ring when any of the co lines is ringing since i have a fax machine connected to this extension and it is programmed to answer automatically
Ringing for each extension and line is done in Panasonic system programming commands 408-410 for Day/Night/Lunch. You turn off ringing for all lines to your fax extension and then just turn on one line for that phone.
Be sure to turn off or delay the fax line ringing to all the other extensions at the same time.
Carl
Nov 03, 2010 | Panasonic KX-TA308 Phone
I HAVE THE MERLIN PHONE SYSTEM 820D2 I WOULD LIKE TO SILENCE CERTAIN NUMBERS FROM RINGING. HOW DO I DO THAT?
Now that's an oldie :-) I have the instructions squirreled away right here
Here's how to program line ringing:
• go to the voice terminal whose line ringing you want to program
• slide T/P switch toward you
• touch a line button (note red lights)
• touch the button again until correct code appears:
RED ON = Ring
RED FLASH = Delayed Ring
RED OFF = No Ring
• repeat this procedure for each line
• return T/P switch to center position.
Carl
Oct 19, 2010 | AT&T Merlin Plus 820D2 KSU Phone
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
Caller id not working on only 1 phone
It's a good bet that that telephone doesn't ring therefore the system won't pass on the caller id information.
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
May 26, 2010 | Avaya 700340193 Corded Phone
Shows 2 in top corner. Not ringing out, is ringing in.
If the line 2 is selected you wont able to recieve or make call..
To change to line 1 , press and hold the # or the * button, you should get LINE 1 in display
Please leave me comment, if you need further assistance or please leave rate this solution
Thanks
Dec 13, 2009 | Nokia 6100
My phone doesn't ring! When I phone my house from say a mobile, it seems to be ringing ok but there's no ring coming from any phone??I have taken every phone out of the sockets, taken out the broadband...
please try different phones one by one while you are confirmed that ringer in high in all phones if you got no ring you must call phone company.
Jul 23, 2008 | Lands Phones
Phone wont stop ringing
this sounds like a short circuit inside the devise. Have a repair specialist check it with the proper tools.
May 15, 2007 | AT&T E5908 Phone
Mitel 5220 IP phone won't ring when the main line is ringing
WOW
Ok this post is OLD, but for anyone else having this issue, this is the solution...
There is a programming feature that states: DELAYED RING on certain lines, meaning you can physically see a call coming in to the system (via line flashing), but it will not ring at your desk till something like the 4th ring(hence the name DELAYED ring).
If your set does not ring, and you pick up the heandset, the phone system doesn't know if you want to answer the call -or- you just want to make an outgoing call...
Therefore the Mitel system picks up internal dialtone and waits for you to make the initial reaction (hit 9 for a line out or hit a line that is flashing on the set).
Too change this option, a Mitel Tech is required...
Jan 23, 2007 | Mitel 5220 IP Phone
Avaya 5400 Series 5410 Phone Logo
163 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
