Question about Dell Dimension C521 PC Desktop
(destop dell c521) the diagnostic light number 2 is on, but there is no expansion card installed, i would like to know what´s wrong wiht it.
(destop dell c521) the diagnostic light number 2 and 3 is on, so what is the problem?
Posted on May 27, 2010
  • 3,940 Answers
Http://www.fixya.com/support/r4282412-find_tno_post_diagnostic_information_dell
If there are no expansion cards in the system, and then the failure is likely the motherboard
Posted on Apr 30, 2010
Error codes
Go to Dell Support > Optiplex 780 Desktop PC > Manuals & Documentation > Dell Optiplex 780 Service Manual,
http://www.dell.com/support/troubleshooting/us/en/19/Product/optiplex-780
Diagnostics > Diagnostic Lights,
"Problem Description - A possible expansion card failure has occurred"
"Suggested Resolution -
1) Determine if a conflict exists by removing an expansion card (Not a graphics card) and restarting the computer.
2) If the problem persists, reinstall the card you removed, then remove a different card and restart the computer"
Be SURE to follow Anti-Static Procedures.
Regards,
joecoolvette
May 13, 2013 | Dell OptiPlex 780 PC Desktop
When my dell c521 is powerd, it hangs after the dell screen loads and hands at the phonix bios screen.the 3 lights in front all stand on, so it does not boot into windows.what is the problem pls
It means that the video cannot be displayed on your monitor. Either your monitor is bad or your video card is bad. If you do not have a video (PCI) card installed then you are using the integrated video circuit built into your motherboard. If that's the case, you need to replace the motherboard.
May 31, 2012 | Dell Dimension C521 PC Desktop
Dell c521 motherboard diagrams problems
Per Dell's support site: If the power light is a solid amber, a device might be malfunctioning or incorrectly installed.
Turn off the computer and unplug from power:
I would remove and unplug everything except the memory and video card. Then plug the computer back in.
If it posts (dell screen and then a hard drive warning), turn off the computer and start reinstalling each component one at a time and turn on between each install. Hopefully one compenent will fail and you will know what is bad and needs replacing.
If the computer still had the amber light, remove one of the memory modules (hoping you have 2) and try again. If it still fail exchange the modules. If this works you have a bad memory chip, reinstall the rest the componets to double check and power on. Replace the bad chip.
If the computer still fails on both modules, remove both, you should now get a memory beep code, if not then the video card is most likely bad and will need to be replace.
Hope this helps
Jan 31, 2012 | Dell Dimension C521 PC Desktop
Solid amber light with fan running, so i assume the power good signal is being received, no diagnostic lights and no POST. I've disconnected and substituted all the drives with known good parts, bought new...
Please let me know if the numlock light responds by pushing the numlock key on the keyboard. If you are using a videocard, please disconnect it and connect the video cable to the integrated video. Make sure you disconnect all the expansion cards. Please let me know if this doesn't work.
May 20, 2010 | Dell Dimension C521 PC Desktop
My dell c521 wont start i have green power light on and number 4 is light up green the fan is also running high
Pretty Much General basic troubleshooting.
  1. Disconnect all external connections except the power, see if error changes. If it does, connect items 1 at a time till issue is isolated
  2. Remove all Expansion cards, see if any change
  3. Disconnect all drives from MB and power supply, see if any chage.
At this point if nothing has changed, replace the motherboard.
May 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dimension e310- Black screen when powering on, 1 & 2 lights blink
Generally, the 1 and 2 Diagnostic LEDs indicate a failure of a PCI expansion card.
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1130520
So remove any expansion cards, see if anything changes. If it does, one of the PCI cards is suspect.
If the system has an expansion video card in the PCI-E slot, and removing the PCI cards had no effect, remove the PCI-E video card and connect to the intergrated video port (You may have to remove a black cover from the port) and see if you get video. If you do, then the Expansion video card has failed.
Nov 21, 2009 | Dell Computers & Internet
My dell dimension C521 has number 3 & 4
http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/tshoot.htm#wp1064555
This gives you a list of every possible fault on this machine! It looks like you will have to contact DELL directly on this one!
Oct 19, 2009 | Dell Dimension C521 PC Desktop
Computer hangs at the Dee Logo
Look at the description for the diagnostic lights on a Dell 2400 here under "A possible expansion card failure has occurred."
If you have recently installed any card (wireless, sound, etc.), then this would be my first suspect.
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
No display on screen
Follow this link for diagnostic error codes for your model: http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/tshoot.htm#wp1064555
It appears that your video circuit has a problem, not the monitor but the graphics card or on board graphics controller.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 09, 2008 | Dell C521 DimensionTM PC Desktop
Dell c521 won't start
- disconnect the hdd and optical drive cables, remove the expansion card, reseat the atx and 12v cable and turn the computer on. if the power led is glowing green connect the devices on by to find what device is causing the no post issue. after the strip down if the power button is still yellow replace the motherboard
Dec 06, 2008 | Dell Dimension C521 PC Desktop
Dell Dimension C521 PC Desktop Logo
227 people viewed this question
Alun Cox
