Question about LG WD-14124RD Front Load Washer / Dryer
Door not closed
My lg washing machine will not start the lights on the panel that are flashing ,indicate door not closed ,i have replaced switch on door but still have same problem?
    Champion:
  • 210 Answers
The other thing may be that you have leaned on your door and bent it so it will not close properly. Expensive repair if this is the case.
Sgt 48
Posted on Jun 02, 2008
    Genius:
  • 1,554 Answers
Open the top of machine, 3 screws in top rear ,
start machine.
lift up on one of the the center black plastic connectors plugged into the control unit.
if that lets it continue then the relays need resoldered to the board.
Posted on Mar 25, 2008
Hotpoint 6kg washing machine Aquarius wash light indicated door lock indicator flashing machine won't fill any ideas thanks Brendan checked filter ok
Many or even most washing machines will not run if the door lock switch is not working. Open and close the door a few times to see if the light stops flashing. You could press on the door where the latch is and see if that makes a difference.
Jun 04, 2015 | Hotpoint Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Where is located sensor of. Fuzzy logic t7517tepto
dE
Washing machine door detected as being open Door open error code can also be displayed as "dOE"
Very simple error, the fault code indicates that either the door is indeed open or that the door lock or door interlock mechanism cannot inform the electronics that the door is properly closed. LG door locks are known to and do commonly fail, the common one used in most LG washing machines and washer dryers can be found here with a link to a lower cost alternative part. However the door handle (can be found here) is also a common source of trouble and, if the catch doesn't engage into the lock properly you will get this fault code being displayed.
On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Dec 10, 2014 | Washing Machines
Why does my whirpool wwdc 7410 not start cycle?
you may have a bad door switch. I would check that the wires are still connected to the switch and that they are not broken or damaged.
May 12, 2014 | Washing Machines
The DOOR LOCK light does not come on.
The error clearly indicates bad door switch. Very simple to fix, have to take top off and loosen switch from front panel. Remove and replace.
Part #131763245 and suggested retail price $50.
Thank you
Jul 23, 2010 | Frigidaire ATF6000ES Front Load Washer
It has de flashing and wont start the washing load
This indicates a "door open" condition. This can be caused by the door not being fully closed, loose electrical connections at the door switch, a faulty door switch, or the gasket on the door may be creased in. Make sure the gasket isn't preventing the door from closing fully. The door switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad switch. Hope this helped and sorry for your trouble. Best wishes.
Sep 04, 2009 | LG Washing Machines
Washing machine not working,door flashing on indicator panel and door lock indicator not on.so washer thinks door is open.
The switch more than likely has to be replaced,< by switch the door latch assembly > it has built in switch to confirm door is latched and if it does'nt work then machine does'nt know door is closed
Apr 26, 2009 | Washing Machines
Door locked indicator light flashing
reposition the switch.. in the door
first try holding button at door with finger and press start..if same symptom appears...check tab that depresses that switch and if its good try to reposition or replace switch.
Feb 26, 2008 | Hotpoint WMA50 Front Load Washer
"Door Locked" Indicator Switch Faulty
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
Aug 18, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WD-14124RD Front Load Washer / Dryer Logo
85 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
