Question about Sharp R530E 1200 Watts Microwave Oven
First the microwave clock etc worked but the fan and table and microwave didn't work now nothing works anymore i checked the fuses they are ok the doorswitches work also ok. what is the next step to do
  • Sharp Master
  • 5,568 Answers
Probably the failure of a high-amperage fuse inside the unit. The electronics are generally separately fused so one section can fail leaving the other functioning.
If there is no external fuseholder on the back panel, it will be necessary to remove the housing to access the innards.
The fuse that has blown may have blown because of metal fatigue but the cause could also be more serious, namely the high voltage diode (or diode bridge) that converts high voltage AC into the DC required for the magnetron or even the magnetron itself may have developed an internal short.
If you locate the fuse, buy two of them and if the first replacement fails again, then the diode(s) or magnetron has failed and with the cost of service plus parts markup, you will be better off replacing the whole unit.
Posted on Apr 30, 2010
My Whirlpool microwave model MH6130XEB-1 made a pop noise and now will no longer heat food. Everything else works fine, clock, timer, fan, turn table, etc. Is this a fuse problem?
It can be the fuse supplying the magnetron, or the magnetron itself which has failed. Another suspect is the high voltage capacitor in this circuit.
Don't try to fix this yourself as the internals of a microwave are dangerous, with high voltages even when unplugged.
Aug 27, 2013 | Microwave Ovens
On model mh1160xss-0 whirlpooll microwave the fuse blows everytime you turn on cook
The magnetron is shorted or the inverter board is defective if microwave is 7 years old or less.
May 16, 2012 | Microwave Ovens
I have a 1995 Sharp Carousel R-1440. Our power went out then when it came on our microwave it no longer working properly. the clock works but when the door is closed the cooling fan starts running- it...
Yes your oven's controller is probably malfunctioning you need to replace the SYSTEM BOARD but I personally suggest to buy an other oven.... the system board will be hard to find and expensive...
See if other electronics is acting funny since the power loss... you could CLAIM the damage from the insurance company
Good luck!!
Feb 28, 2011 | Sharp R-1460 Microwave Oven
Microwave not heating
it can be saved but get a quote from the shop first before proceeding and always evaluate it against the cost of a new one,
it could be the power supply has shorted but check it out.
Jul 29, 2010 | Daewoo KOG-867T Microwave Oven
Hi, My microwave oven stopped working after I came home from four days of vacation. The digital clock works. What could be the problem? The turn table does not work. Is there any danger opening back of...
if the clock is working then the fuse is fine. if the fuse goes bad the unit would be completly dead. no their is danger removing back panel. as you said make sure the unit is inplugged., however some electrical parts inside hold a charge until discharged.the board could be bad, the door latch or switches could be bad.
Sep 19, 2009 | Sharp Microwave Ovens
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Sharp R530E 1200 Watts Microwave Oven Logo
77 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
