Question about Avanti DG-20CW-1 Gas Kitchen Range
Ignitors won't stop sparking
The stove top ignitors will not stop sparking. had to unplug the range
  • Avanti Master
  • 43,501 Answers
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Rangeignitors won't stop sparking - 2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on May 04, 2010
Burners light but ignition keeps clicking
use a blow drier to dry the igniter and knobs.
May 21, 2014 | Jenn-Air Kitchen Ranges
Stove top burner ignitors will not turn off
Gas Range2_bing.gif Repair Burners Keep on Clicking
heatman101
Apr 30, 2010 | KitchenAid KGST307 Gas Kitchen Range
How do I access a spark ignitor on a Viking gas
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by a 'tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and would cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range. Of course you need to ensure it is the correct one for your stove. The ignitor you remove should have a manufacturer part number on it. No calibration required on mine - a sealed electronic unit. Probably about 10 wires that need to be R&R'ed - they are on with reuseable fasteners.
Jan 18, 2010 | Stoves 600SiDOm Gas Kitchen Range
Ignitor will not stop clicking
Marguerita , In addition to turning off the gas valve going to the stove, FIRST, unplug the stove from the electric outlet, so the high voltage ignitor (spark) will not be constantly operating and elminate the possibility of getting a serious jolt/shock.
Just follow Jumptrout's well described troubleshooting and repair instructions, but please uplug the range first and go one wire at a time, cleaning them and retrying them, or better yet, just clean them all; removing them one at a time, cleaning one, and putting it back in place until you've cleaned and reconnected them all.
Hope you find this Very Helpful and best regards!
Dec 01, 2009 | Tappan TGF320 Gas Kitchen Range
Maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
Jul 01, 2009 | Maytag MGC5430 Gas Cooktop
Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
May 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag gemini gas stove. Ignitor problems
My experience with this is that it occurs when moisture gets into the ignitor area and shorts out the open and causes the spark. It stops after it drys out.
This is very non-techinical and I will defer if there is a deeper solution.
May 14, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Ignitor on stove top keeps engaging when all burners are off.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ioy
Mar 21, 2009 | Viking VGIC485-6G Gas Kitchen Range
Spark ignitor won't stop clicking
Dry the ignitors and see if that works. If not, then get new ignitors.
Apr 14, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Avanti DG-20CW-1 Gas Kitchen Range Logo
416 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
