Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
455 wont run
I have a saw bought last yr ran fine. this spring it refuses to start, changed the gas/oil mix,new spark plug and air filter. it has lots of spark and compression but wont fire. im not familar with two strokes , any ideas? i also tried using starting fluid not even a pop.
    Brigadier General:
  • 4,088 Answers
Make sure the muffler has not become plugged. Check the flywheel key as it may have sheared off for some reason causing the timing to be off, yet still generate sparks. Are the sparks blue and snappy? If not, check the ignition module gap to the flywheel magnets--use a thin business card for a gauge. A wide gap can cause weak spark. Hope this gets you running again!
Posted on May 04, 2010
Was using saw ran fine stopped and returned next day will not start fuel fine new plug filterers gas and air still wont start took to local chain saw repair shop they said that because it had water in gas...
check the carburetor. If you have a stiff diaphragm then it won't run.
I have seen them that behave just like that. They will run fine, turn it off for a few minutes then they won't restart. WD40 isn't going to get it to run either, try a small amount of mixed gas right into the carb. It should run for a minute until the gas you put in runs out then die. If it doesn't run then you have a bigger problem
Jan 30, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Honda 6500is wont start ran about 6 months ago drained fuel put new fuel in still wont start.
make sure you are getting fuel to carb, also check spark plug
Jun 12, 2011 | Garden
Husqvarna 51 died and wont restart
hi
if you have a good compression,a strong enough blue spark and carburetion for the fuel air mixture try priming the engine(put small amount of gas in the spark plug hole)then start the engine.If the engine runs only the gas you put inside the cilinder there is a carburetion problem to find and fix.
let me know regards savumihai71
Apr 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a 455 rancher that is difficult to impossible to start. If I get it started and stop it it won't start back. when it starts it runs fine. I took the plug out and cranked the engine and there was a...
my 455 did this also I went and bought a new gas filter new gas and mix. try this you might have some water in your gas,also add some sea foam additive to your gas mixture just about a table spoon to 2.5 gallons of gas
Feb 23, 2010 | Husqvarna Garden
My 455 starts good and idles fine but wont go wide open it boogs down and misses
Here are a few things to consider :
- fresh fuel ratio 40:1
-new spark plug
-choke not sticking
-air fuel mixture correct
-bar and chain oil tank full, oil getting on chain
-bar sprocket in good shape getting lubed.
Please let me know what you find.
Feb 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 455 rancher i have spark (dont know if good spark) and gas new spark plug and air filter and it wont start.
Check to see if your ignition switch ( on& off) switch still have both wires attached. Common problem with that saw, loose or disconnected wire
Aug 16, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
1985 40 hp Johnson outboard wouldnt open up and
sounds like your mix is off and it's fowling the plugs. probably too rich. make sure the level in your carb bowls isn't too high. Really sounds like you should clean and bench set your carbs. Especially if a plug change helps but doesn't last, then it's got to be your fuel mix, or maybe timing.
Jul 16, 2009 | Sport & Outdoor - Others
Chain saw emitted sparks and now does not start.
Hi
When the engine get warm and die(I suppose)check the spark at the sparkplug.You can let the saw run until it ran out of gas and you will not distroy the engine.Change the sparkplug.
best regards savumihai71
Dec 16, 2008 | Garden
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
357 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
