FixYa.com
Tags:
JVC FS-V30 CD Shelf System
SP-UXV30 speakers
posted by pjsales on Mar 25, 2008
I would like to replace damaged 4cm tweeters on the JVC UX-V30 shelf system. The speakers have a 4 ohm impedance and rated at 26W each. They each have a 4cm tweeter with 8 ohm marking on it and a 9 cm woofer with a 4 ohm marking on it, linked with a crossover cap. Any idea as to the power handling (W) of the tweeter or what I can safely replace them with. Any info appretiated.
pjsales
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 25, 2008
Helpful (85)
Benimur
Rank:Guru Guru
Rating: 86%, 1985 votes
Offhand, the tweeter can be rated similarly to that of the woofer but not lower than 26 watts. I think your concern should also include the physical mounting and size since most branded units would be using proprietary components/parts and are not readily available.
Most electronics parts store would be carrying "generic" tweeters and "as per sample" would be your best basis. If I understand it right, **** Smith in Australia would be similar to Raon Stores in the Philippines or Akihabara in Japan.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Rating Locked! (?) pjsales has rated this solution as Helpful
Can you Help with these Audio Shelf Systems problems?
Audio Shelf Systems
giga juke
cant get the wireless part of... Answer This...
Audio Shelf Systems
AIWA Xr M6 C.D player won't...
Hallo can you please advise?... Answer This...
Audio Shelf Systems
Trouble getting ipod nano to...
New GPX Home Docking System... Answer This...
Audio Shelf Systems
Aiwa User Manual for NSX-SZ10
Where can I buy one of the... Answer This...
Audio Shelf Systems
HOME STEREO SYSTEM CD PLAYER
i have a aiwa... Answer This...
Repair Service
Find Audio Shelf System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
