Question about Linksys Wireless-N WRT150N Router
Cannot access the router. Reset as directed, still no access. Directly connected to PC, still no connection. Cannot see 192.168.1.1, default IP address! Is the unit FUBAR? If so, where can I send it to repair the unit?
  • Linksys Master
  • 2,263 Answers
Your computer is connected to the router. check the port lights on the router. If your computer is connected to number 1 port on the router then you will see port 1 light on the router.
Connect your computer to one of port 1, 2, 3, or 4. Not to the Internet port.
If the port light is not lit up then check the connections. Make sure that there is no loose connection.
If ti is lit up then check the IP address on your computer. The default gateway number wil be the IP address of the router. Use that number to access the rotuer settings. Some times the Ip address of the router will be different ( Depends on ISP ).
Once you have correct I address of the router then try to ping that number and check if you get replies.
Click here for more information abotu router and networking
Posted on Apr 30, 2010
Verizon dsl and cisco valet
Connect your computer directly to the Internet modem and make sure that you have Internet access directly from the modem.
If that is working properly then connect the modem to the Internet port on the router. Connect the computer to port 1 on the router.
Reset the router and configure it manually.
Here is link which will help you troubleshoot Cisco Valet M10 or M20 router
Mar 01, 2014 | Linksys by Cisco Cisco Valet Plus Wireless...
Can't access internet, says I am connected but then says no internet connection
I think you should try to reset and reconfigure the Linksys router and see if that works.
If your Linksys router is old then you can also upgrade firmware on the router.
Connect your computer directly to the modem and make sure that you can access Internet directly through the modem.
Connect the modem and computer to the router. Open the setup page of the router and change the settings manually.
Try this website to setup your Linksys router manually.
I can also suggest you a Fiverr Gig where you can pay only $5 and get support for your Linksys router.
Jun 11, 2012 | Linksys Wireless-G Broadband Router
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
Cannot access 192.168.1.220 in web browser. Need it to set up WL-330GE as a repeater
If you have your asus WL-330GE connected to a router and you are trying to access it from another pc connected to the router...it will not work. You need to connect directly to the asus unit.
Then...
1)You will need to configure your computer to talk to it by changing the TCP/IPv4 under your LAN connection settings> Properties to read Manual IP of 192.168.1.10 if reset or 192.168.40.10 if not reset. then...
2) type 192.168.1.220 if you have reset it. Or 192.168.40.1 if it is not reset.
default user/pass is admin/admin for a reset unit.
Dec 29, 2010 | ASUS WL-330GE 802.11b/g Wireless Access...
Cannot connect to internet via wireless router
You better reset it to the factory settings and reconfigure
Nov 08, 2009 | NetGear WGR614 Wireless Router
Lost connection and can not access 192.168.0.1. have reset and nothing. have vista
Try connecting to the router with a lan cable, It may be that the wireless settings have become corrupted.
Nov 03, 2009 | D-Link AirPlus DI-614+ Wireless Router
No connection between modem-router-pc
Linksys reset
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
Router setup
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPPOe.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 13, 2009 | Linksys Wireless-G WRT54GS Router...
Can't connect to configure password through web address 192.168.0.50
what you were missing is the fact that if you directly connect router to pc you will have to change ip on pc to match router i.e you are trying to connect to router through ip listed above then you should make ip on pc 192.168.0.***.
May 11, 2009 | Computers & Internet
Wireless router connection problems
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Dec 29, 2008 | Linksys Access Point WAP54GP Wireless-G...
Linksys Wireless-N WRT150N Router Logo
160 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
