Question about Visioneer One Touch 7600 USB
One touch 8700 scanner
The problem is that with windows xp I cannot use the 8700 scanner because it is for 98 windows is there some way to fix this by either software ,adapter, or some other way.
Please reply to dfalorca@yahoo.com.
Thanks Donna Falorca PS the scanner has hardly been used.
    Master:
  • 351 Answers
Dear Donna,
please download the latest driver for your 8700 Scanner for XP ,from this site:
http://www.driver100.com/driver/128/2222/Visioneer_8700_Scanner_USB.html
i'm 100% sure that your scanner will work with XP now.
Cheerup And Be Happy Always
Posted on Mar 25, 2008
Is the Pandigital SCN02 Photolink One-Touch Scanner compatible with Windows 8?
Are you using it currentrly? What is your current Operating System? I've been searching and can't see anywhate a windows 8 driver for this scanner.
Bu let me tell you, I'm using currently a Genius ColorPage, originally released for windows 98. Installed windows 2000 driver in compatibility mode for findows XP. There is no driver for Windows XP nor for Windows 7 and coldn't make it work in Windows 7. So I run it on a computer with dual bootWindows XP / Windows 7.
When I need to scan, I simply start up as windows XP. When finished scanning, reboot to windows 7
I Have Windows 7 on a 2 Tb HD SATA and Windows XP on 200 Mb IDE. Is more economical to have a dual boot then buy a new Scanner.
If your scanner won't run on windows 8, install on another HD or a partiton, Windows 7. doual boot Windows 7 / 8 work like a dream.
See comments for this scanner in Amazon;
Amazon com Customer Reviews Pandigital SCN02 Photolink One Touch Scanner...
Jun 11, 2015 | PANDIGITAL Office Equipment & Supplies
Xerox 4800 one touch flatbed scanner My new computer has Widows 7 and the scanner will not work with it. Do I need another drive
Hello.
I am a Support Engineer with Xerox Scanners.
The Xerox 4800 do not have a supported Windows 7 driver. The scanner only supports Vista, XP, 2000, ME, and 98. I recommend trading the Xerox 4800 for a supported windows 7 scanner.
Please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Nov 21, 2012 | Xerox One Touch 4800TA Flatbed Scanner
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
Jan 03, 2011 | Visioneer OneTouch 8700 Flatbed Scanner
I had a new install of windows xp (with service pack 3)on my computer and am now trying to install my visioneer one touch 8700 scanner. Is there a problem with the driver and the xp service pack 2? How can...
You will have to uninstall the device. Delete any files it created on the drive as part of the install. (Not things you'[ve scanned, just program files) then disconnect the scanner. Reattach the scanner in a different USB port (different SCSI id if your using SCSI) and let Windows re-detect the scanner.
This time don't run the setup from the driver CD. Instead let Windows find the scanner and try and set it up on it's own, if it prompts you for a driver, point it to the INF file in the installer directory. If it doesn't, let it use the one it chooses.
After installing in this way you should be able to use the scanner as a TWAIN source from any application.
Apr 19, 2010 | Visioneer OneTouch 8700 Flatbed Scanner
My visioneer one touch 8700 scanner shows up not
Hi Margaret,
I think are you using windows Vista and Visioneer one touch 8700 won’t work with that but this scanner work with Windows XP with SP 1 / 2000 Pro / Me / 98SE
And Thanks.
Mar 27, 2010 | Office Equipment & Supplies
Need drivers for windows xp pro 64
The XP driver is available at:
There is no indication of 64-bit or 32-bit support. However, the driver is not guaranteed to work with XP SP2 (only tested with SP1). This suggests that SP3 is also not tested.
I wish that I could be of more help.
Mar 25, 2010 | Visioneer OneTouch 8700 Flatbed Scanner
How can I install one touch 7600 scanner without an install disk?
What OS do you have? The manufacturer's web site offers drivers for Windows 98/Me or Win 2000 and XP:
http://support.visioneer.com/products/7600/downloads.asp
If you have a newer OS, you can try installing the driver in the compatability mode but it may not work.
Please note that the scanner is officially not designed for XP and is not supported by the manufacturer any longer (end-of-life). The supported Operating Systems:
  • Windows 2000 / Me / NT 4.0 / 98
  • Not Designed for Windows XP
I hope this helps.
Feb 18, 2010 | Visioneer One Touch 7600 USB
My computer window xp cannot connect to my one touch 8700 scanner,, I have use this scanner on my 98 computer
You must doownload windows XP drivers. Go to http:/support.visioneer.com, and left click on SUPPORT AND DRIVERS at the top of the homepage. Left click on SCANNERS FOR HOME, and on the next page, left click on your scanner's icon. Now, just follow the instructions on the page to download and run the updated software.
Aug 10, 2008 | Office Equipment & Supplies
Updating my scanner from Windows 98 to Windows XP
plz visit the manufacture website and download the drivers for free
Jul 01, 2008 | Visioneer One Touch 7600 USB
128 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Level 1 Expert
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
