Question about HP LaserJet P3005 Printer
My printer will not print the 1st document. It will come up as an error, and then I cancel that one. Then I RE-PRINT the same document and it works the 2nd time. Any idea's why my printer is doing this?
    Scholar:
  • 67 Answers
Do a Cold Reset. This will return the printer to the original factory settings. But first, print out a configuration page so you will have a record of any custom settings you may want to re-enter after the reset. To get the config page, press the Go button and hold until 2 lights begin to flash, then release the button.
To do the Cold Reset:
1) Turn the printer off
2) Turn the printer on. As soon as the memory count starts onn the LCD display, press and hold the SELECT button. Continue holding it until all 3 lights flash once then remain on solid. This can take up to 10-15 seconds.
3) When the message SELECT LANGUAGE appears on the LCD display, press the UP or DOWN button until COLD RESET is displayed.
4) Press SELECT. This will start the Cold Reset process. When it's finished it will continue the power on sequence.
5) Send a job to the printer for a test.
Posted on May 02, 2010
I need free support to empty memory of brother HL-2140 printer
This error occurs when your printer is dealing with a particually complicated print job and cannot process it all. Try to reduce the complexity of your document or cut the print resolution. It may be worth trying to print the document in several parts if at all possible.
I hope this helps.
Dec 27, 2012 | Brother HL 2140 Laser Printer
How cancel the print job in cannon lbp 2900 printer
Hi and welcome to fixya,
Go to control panel > Devices and Printers
double click your printer, you'll be able to see the queue...Right click on the document and select Cancel printing.
You can alternately push the power button to immediately stop the current page being printed. You will receive an error message but click cancel and proceed normally.
Hope this helps
Feb 03, 2011 | Canon LASER SHOT LBP-2900 Printer
Error message stating 8documents waiting to be printed. I cancelled them but the printer will not print new documents. there were previous documents printed and I did not want to finnish those documents so...
Sounds like a driver problem. I would try disconnecting the printer from your computer and power cycling it (unplug it for a few minutes). While it's unplug uninstall and then reinstall the print driver. If that does work email me.
panderson@cartridgeworldusa.com
Jan 14, 2010 | HP Officejet 5610 All-In-One InkJet...
How do I cancel unwanted print jobs.
on the printer driver has a spooler area. to enter this area go control panel, printers and faxes, enter your printer, then select the print jobs and on top has a menu document, and choose cancel . the 1st print job is printing, so takes longer time to cancel.
Dec 28, 2009 | Epson Stylus Photo 1400 Printer
Having problems deleting pending documents
Assuming you have a modern windows pc, You will need to manually stop the print service. Do this by running the command "net stop spooler" from the "run" line. Then go to "C:\WINDOWS\System32\spool\PRINTERS" and delete all the files from there. After these files are gone, start the spooler service again by running "net start spooler". You should be all set after that.
Jun 09, 2009 | Office Equipment & Supplies
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printer stopped working
Turn printer on and off if that doesnt work then ust restart, sometimes things get stuck in the queue.
Apr 24, 2009 | Lexmark X1150 All-In-One InkJet Printer
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Will not print after turning printer off
I used to have that same problem what i suggest doing is restarting not only the printer but your computer aswell. That seemed to solve the problem for me
Oct 15, 2007 | HP LaserJet 1020 Printer
HP LaserJet P3005 Printer Logo
144 people viewed this question
Seeker5211
Seeker5211
