Question about Dictaphone 2750 Desktop Cassette Transcriber / Recorder
Foot pedal does not work for my Dictaphone model 2750 Where can I purchase a replacement
  • 43 Answers
Make sure the foot pedal is plugged into the SIDE of the machine and not the BACK of the machine. I've seen many people make this mistake...
Posted on Jun 18, 2010
Best dictaphone for conference Recording
Hello the Dictaphone 2740 does not have the option for telephone record or conference recording you need the Model that is really similar to the 2740 the model is 2750 this model has telephone record option and conference record capable.
Note: for telephone record you need to buy a separate adaptor like this ECS-DPRC
Aug 12, 2011 | Dictaphone 2740 Desktop Cassette...
My dictaphone is playing super fast. I do not know what is wrong with it. If anyone can help me that would be great. Thx!
Hello make sure the Speed control at front is on center if yes when is hapening make sure that you press the play button on the unit wile this is hapening just unplug the pedal if the problem get fix playing, your unit with out foot control you need a foot pedal replacement if not sounds like a bad motor I'm senting a link for a replacement pedal and a service place in case you need to send your unit to repair http://www.tvps.com/Products/ECS-IN-585-Heavy-Duty-Foot-Pedal---Pre-Owned-IN585__ECS-P-IN-585.aspx
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Nov 08, 2010 | Dictaphone 1740 Desktop Cassette...
I want to transfer files that were recorded on a dictaphone on to another dictaphone to play. How do I do this? The files are the same format and when I move them the dictaphone doesn't have them to play
Can't you simply take the tape from the 2750 and put it into the other Dictaphone to play it? Or is the other Dictaphone a different size tape (eg; mini or micro)?
Aug 24, 2010 | Dictaphone 2750 Desktop Cassette...
Necesito el diagrama electronico del Dictaphone 2750. Tengo una falla del circuito y necesito el diagrama para poder detectarla. No me llega tension al motor. Gracias. Herberth
Sorry, I don't speak spanish, but try replacing Q609 on the main PCB. It's located on the top, towards the front of the machine.
Also make sure that the motor doesn't have a 'flat spot' (that it stalls). This is generally what blows the Q609 transistor. If you have power to the machine and a cassette in, try manually turning the motor to see if it'll start on it's own.
Apr 20, 2010 | Dictaphone 2750 Desktop Cassette...
How to transfer voicemail onto cassette tape using Dictaphone 2750
Hello you will need and phone recor adaptor I recomend to used http://www.tvps.com/Products/1ECS-DUPR-Telephone-Record-Adapter---New__ECS-DUPR.aspx when your are ready just press and hold for 2 seconds telephone record button on your Dictaphone 2750 when your listen to your voicemail.
Apr 05, 2010 | Dictaphone 2750 Desktop Cassette...
Necesito ayuda urgente si ustedes son tan amables de ayudarme se los voy agredecer yo necesito el service manual porque compre 10 dictaphone 2750 desktop tengo problema con tres de ellos porque el motor se...
Hola Soy Tecnico en servicio de SONY y Dictaphone Y estas en lo correcto el modelo de Dictaphone 2750 Stadard cassette uno de sus problemas es que si la unidad queda con el cassette dentro y sin seleccionar auto encendido el motor queda funcionando asi que se muere mas rapido la verdad es que necesitas remplazar el motor y el motor solo tine dos cables asi que no es mayor problema el remplazarlo te puedo dar un correo para que solicites el motor normalmente esta compania no vende partes solo da el servicio de reparacion de las maquinas pero puedes decirles que Javier te recomendo para comprar estos motores que nececitas, despues de remplazarlo tus maquinas quedaran bien otraves email to service@tvps.com
Nov 30, 2009 | Dictaphone 2750 Desktop Cassette...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Lost manual for dictaphone 2750
For transcribing, you'll need the machine (2750), the power supply, a foot control, and a headset (unless you use the machine's built-in speaker).
For dictating, you'll need the machine (2750), the power supply, and the microphone.
Mar 11, 2009 | Dictaphone 2750 Desktop Cassette...
Dictaphone foot pedal
It would be easier/cheaper to buy another foot pedal.
The older style had "leaf" switches in them and they are adjustable from below the foot control. There are 2 screws underneath each switch. Loosen up the one closer to the front of the pedal (just a little) and tighten the one in the back the same amount. This will raise the angle of the switch to make it more sensitive (lighter pressure to activate).
Oct 10, 2008 | Dictaphone Audio Players & Recorders
Dictaphone 2750 Desktop Cassette Transcriber / Recorder Logo
142 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Alan W Kelly
Alan W Kelly
Pennywhistler
Pennywhistler
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
