Pls hepl me wit Excel VB integration
Hi.. I am doing my chartered accountancy.. during my audits, i come across thousnads of excel data, which i am now looking to access through VB and do some simple programming wi that data. so pls help me wit a way to access my excel data with VB... expecting your reply soon.. thanks
You can use a OLE object that is available in VB as standard object. Drag the tools to your form that your creating and it will ask for create or link existing object. so now browse to the excel sheet and embed it into the VB form or use run time for manuplating the cells and other info in excel.
Posted on Mar 26, 2008
SOURCE:
Delete blank rows in excel using visual basic
have you tried to read in one file and write back in excel format only the non-blank rows?
Mar 11, 2009 | Sony Playstation 3 (PS3) Console
Tip
How to Backup Your Outlook Contacts to Excel File?
Microsoft's Outlook is integrated into Microsoft Office 2000, 2002, 2008 and Microsoft Exchange Server. Outlook is complete e-mail manager by which you e-mail, calendaring, and contact management. Outlook enables you to filter and organize e-mail messages, integrate and manage e-mail from multiple e-mail accounts, personal and group calendars, contacts, folders, and tasks.
Using Import and Export feature in Outlook, you can create the full backup of outlook contacts. Because without backup yon can lose your e-mail accounts data any time due to virus, power failure and hard disk problem.
Follow the given steps to export your outlook contacts to Excel file:
Click on Start button, go to Program then click on Microsoft Outlook to export the contacts.
Now go to File menu and click on Import and Export option. Choose Export to a file as show in the below figure then click Next.
export-computerfreetips.gif Now on next dialog box, choose Microsoft Excel and click Next.
export-computerfreetips1.gif Select the Contacts Folder you want to backup to Excel file as shown below then click Next.
select-computerfreetips.gif Choose a name and location where to save the Excel file by clicking Browse button, then click Next.
file-computerfreetips.gif Click Finish to start the back up procedure which may take little time depending on how many contacts you have.
on Jan 29, 2010 | Computers & Internet
Code for upload data form microsoft excel to sql server
you wan the code for sql loader right? or you want the procedure to do that?
Feb 08, 2009 | Microsoft Computers & Internet
Excel
VBA is an integral part of Excel. Search help for VBA, and you should be guided to the proper place. Please post back if you need more help, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
Vb project
One of three ways:
1 make the table using vb creating a Bload screen.
2 using the visual data manager.
3 import a windows access or excel data base table.
Try the data wizard, easiest to use and U can program the program to manipulate the data in the tables.
May 29, 2008 | Computers & Internet
Excel formula
The IF() is the wrong one to use. Use "Iif()", as in:
=IiF(A3='Audit Exception Register'!B:B, COUNTIF('Audit Exception Register'!P:P,Y), 0)
See:
http://pubs.logicalexpressions.com/Pub0009/LPMArticle.asp?ID=799
Caveat about using Iif(), one that doesn't probably apply in this case, but keep it in mind: Don't use Iif when trying to return the values of "real" objects. Examples of "non-real" objects in the VB/A world are:
String
Integer, Double, etc... all the numeric "objects"
Boolean
These are fine to use in IIf() statements. If however you will be returning some value that is part of an object, as in:
Iif(x=2, myObject.getSomeVal(), 0)
You run the very real risk that is myObject is null, your program will simply stop running. Iif() will NOT return a null error/exception; it will in fact just stop. This is a bug in the VB interpreter and/or in the Iif() function itself.
I am referring here to classic VBA (ie, pre-VB dot-Net). How .NET handles such cases, I don't know.
Mar 07, 2008 | Computers & Internet
Export data in excel shld yoeet through VB
When i first figured out how to pull data from SQL and put the results in an excel file i referenced these two articles....
Reading and writing excel file using VB.NET (http://www.codeproject.com/KB/vb/Work_with_Excel__VBNET_.aspx)
Get the Values From DataBase and Stored into excell Sheet (http://www.codeproject.com/KB/vb/Getvaluesfromdatabase.aspx)
This is the code i ended up using.... (check out those links to see how you need to import the ms office excel reference file with visual basic)
Const stcon As String = "Provider=SQLNCLI;server=xxxxx;database=xxxxx;uid=xxxxx;pwd=xxxxx;DataTypeCompatibility=80"
Dim stSQL As String = "select * from scs_rate_class_money where irate_book = 124 and snew_used = 'U' and sclass = '2' and splan = 'T4' and sopt_code = 'F1'"
Dim cnt As New ADODB.Connection
Dim rst As New ADODB.Recordset
Dim fld As ADODB.Field
'Open the connection.
cnt.Open(stcon)
'Open the recordset.
With rst
.CursorLocation = ADODB.CursorLocationEnum.adUseClient
.Open(stSQL, cnt, ADODB.CursorTypeEnum.adOpenForwardOnly, _
ADODB.LockTypeEnum.adLockReadOnly , _
ADODB.CommandTypeEnum.adCmdText)
.ActiveConnection = Nothing 'Disconnect the Recordset.
End With
'Close the connection
cnt.Close ()
Dim exp As Export = New Export()
Dim xlApp As New Microsoft.Office.Interop.Excel.Application
Dim xlWBook As Microsoft.Office.Interop.Excel.Workbook = xlApp.Workbooks.Add(Microsoft.Office.Interop.Excel.XlWBATemplate.xlWBATWorksheet )
Dim xlWSheet As Microsoft.Office.Interop.Excel.Worksheet = CType(xlWBook.Worksheets(1), Microsoft.Office.Interop.Excel.Worksheet)
Dim xlRange As Microsoft.Office.Interop.Excel.Range = CType(xlWSheet, Microsoft.Office.Interop.Excel.Worksheet).Range("A2")
Dim xlCalc As Microsoft.Office.Interop.Excel.XlCalculation
Dim i As Short
'Turn off Excel's calculation.
With xlApp
xlCalc = .Calculation
.Calculation = Microsoft.Office.Interop.Excel.XlCalculation.xlCalculationManual
End With
'Write the fieldnames.
For Each fld In rst.Fields
xlRange.Offset(0, i).Value = fld.Name
i = i + 1
Next
'Populate the range.
xlRange.Offset(1, 0).CopyFromRecordset(rst)
'Close the recordset.
rst.Close()
'Make Excel available to the user.
With xlApp
.Visible = True
.UserControl = True
'Restore the calculation mode.
.Calculation = xlCalc
End With
'Release variables from memory.
fld = Nothing
rst = Nothing
cnt = Nothing
xlRange = Nothing
xlWSheet = Nothing
xlWBook = Nothing
xlApp = Nothing
Jan 03, 2008 | Computers & Internet
Excel Loading Problem
try using OpenOffice.org instead of Microsoft Office. It should work and it's free.
Dec 07, 2007 | Microsoft Excel 2000 Step by Step...
Auditing in Excel
Dear raajee, Auditing in excel if fairly easy. It can be find by pressing Tools > Formula auditing and then further options. Complete introduction these options are availible on this tutorial:
http://exceltips.vitalnews.com/E037_Auditing.html
Please press solved if that has helped you.
Nov 14, 2007 | Microsoft Excel for PC
Import excel sheet in vb.net 5
you have to make link in you vb then you can save the xls files on same format
Oct 08, 2007 | Microsoft Office Standard for PC
Open Questions:
Aol verizon Number 1=855=536=5666*$+ -Aol verizon helpline number- EGJRZWI [email protected] assistance available 24*7. If you are facing any issues in printer you will get expert assistance through [email protected] helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. [email protected] SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... [email protected] Support Phone Number +{1-855*536*5666*} to resolve all [email protected] products. is an American multinational company which was founded by Michael [email protected] its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. [email protected] is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, [email protected] number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees [email protected] cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL [email protected] cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. [email protected] cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America.
Oct 21, 2019 | AOL Computers & Internet
Computers & Internet Logo
161 people viewed this question
Ekse
Marvin
Marvin
