Question about Microsoft Windows Vista Ultimate Edition
Unable to read cdrom burn in XP - Microsoft Windows Vista Ultimate Edition
  • ttrr3 May 11, 2010
    Find Your solution Direct from Microsoft Support website
    www.microsoft.com/support/?sr=showthr774
    a
    Scholar:
  • 64 Answers
Either run this tool on ur computer http://support.microsoft.com/gp/cd_dvd_drive_problems
or if u want to learn how to do it urself.. then heres the answer.. BE VERY VERY SURE OF WHICH SUBKEY U DELETE OFF THE FOLLOWING OPTIONS.. HOWEVER IF U DO IT PROPERLY.. UR A CHAMP..
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
need more help .. let me know.. regards, Guru :-P
Posted on May 05, 2010
How to fix disk controller failure 1782
Try going here http://www.hirensbootcd.org/download/ burn to disk so many useful things.. Run Mini XP
Oct 05, 2014 | HP Compaq 6710b Notebook
What dose this do
DVD burner or writer is a device where you can write a blank cd or dvd for data,music and videos format and also you can play or read your favorite cd or dvd mp3, audio cd and videos format. For burning you must have nero, alcohol and other burning application. In windows xp, vista and 7 are already included, simply drag your data or files you want to burn to you cdrom drive with blank cd or dvd.Then there is a button burn, click that button to write the files onto your cd or dvd. Have a nice day!
Jan 28, 2011 | Pacific Digital (U30274) DVD±RW...
CDRom you are downloading to is read only
There are many other softwares you can use. try ACDsee
Aug 18, 2009 | Sakar DIGITAL CONCEPTS VC-16 Motorized...
I have a lite-on dvdrw sohw-1633s that windows xp will not detect the driver. it shows cdrom.sys driver how do i fix this? I have burned dvd's befor and don't know how or why the driver changed.
Windows xp does not have a native driver for DVD writers. It always detects them as cdrom.sys. You need to use either the writing software supplied with the drive or Nero or equivalent
Jul 02, 2009 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
DVD-Rom will read the movie but won't write (burn) it. Bad block of memry
>> The Device has a bad block of memory, which Windows attempted to read.
Which CD/DVD disk are you trying to _read_ ?
Can you read this disk in a different computer ?
If not, then the disk is scratched or greasy or otherwise damaged.
Does the error occur when you try to start to _write_ ?
If so, the "blank" CD/DVD media may not be compatible with your hardware.
Find a "writable" disk from a different manufacturer, and try to write to it.
If that works, then you may need to do a "firmware-upgrade" on your CD/DVD-writer, to make it compatible with newer "blank" media disks.
Apr 25, 2009 | Computers & Internet
Unable to boot win xp cd. not detected by compaq presario 5000 series interneal cd rom LTN 403 DQ24
Drive requires cd drivers to run Boot CD.
Some versions came with floppy disk to start cdrom drives, This will also require a floppy drive.
You may also try hitting f10 to enter bios setup make sure cdrom is bootable.
Mar 08, 2009 | Computers & Internet
Booting problem
Install MS Windows XP / 2003 / VISTA CD setup file (ISO file)
Then
  1. Start the computer with your chosen boot disk.
  2. Change to the cdrom drive.
  3. Go into the \i386 directory on the cdrom.
  4. Run WINNT.EXE to begin the install process.
Nov 21, 2008 | Microsoft Windows XP Professional With...
HP Pavilion zv5000 CDRom Problem
Please increase your ram and cd model may be your system is not supported for this type of large type of applications
Jun 22, 2008 | HP Computers & Internet
My drive will read DVDs but not CD/CD-ROMs
If your DVD/CDROM is not working ie..playing movies or not installing programs it may be because you have installed a software program that edited the regitry for the DVD/CDROM - (Limewire, any burning software, etc..) windwos installs an Upperfilter and or a Lowerfilter in the registry for the CDROM - to correct this follow these instructions:
To resolve this problem, remove the affected filter drivers.
To do this, follow these steps:
1. Click Start, type regedit in the Start Search box (Vista) or regedit in the Run box (XP), and then click Regedit in the
Programs list if in Vista or click Open in XP.
If you are prompted for an administrator password or confirmation, type your password, or click Continue. (Vista)
2. Locate, and then click the following registry subkeys: (must be exact keys)
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Once you have clciked Class the click Edit on the menu at the top
Copy and paste the following key inclcuding the curly braces into the Find What box.
Click "Find Next"
3. Highlight by clicking on "UpperFilter" and "LowerFilter" ONLY - then hit Delete on the keyboard and select Yes
4. Shutdown and restart the computer
Feb 19, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Reading Data CD's
Hmmm... were the cd's originally burned using that laptop? Or were they burned on a different pc?
It could be as simple as your cdrom doesnt like something about those cd's. Or it could be a flakey cdrom.
My suggestion, try reburning them to a different brand of disk using a different pc. Then see if your laptop will read them. If not, may need to replace the cdrom. Though it reads commercially manufactured cd's, if its flakey, it will have problems reading custom made cd's.
Other option, get a usb flash drive and copy those files from that cd, in a different pc, to the flash drive.
You don't need any special drivers or programs in order to copy mp3 files from a cd to your hard drive. Yet, you would need something in order to play them. Which media player does just fine.
Flakey cdrom or flakey cd's... hope this helps.
Oct 29, 2007 | Dell Latitude D600 Notebook
Microsoft Windows Vista Ultimate Edition Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
