Question about Technics SL-1200MK2 Turntable
Record only plays through one speaker
My turntable plugged into channel 2 of my mixer only plays through one speaker. is something wrong with the turntable?The turntable plugged into channel one plays through both.
    Brigadier General:
  • 8,546 Answers
If it works on Channel One it is NOT the TT. It's a mixer problem. Define the mixer and what else works or doen't work. have you tried another device on Channel 2?
Posted on May 01, 2010
Blown speaker
Swap the speakers around to make certain it's the amp that causing the problem. Since stereo amps are two mono amps put together you have one good channel to compare the other one with. Sometimes a visual inspection will show what's wrong with it.
Jul 10, 2013 | Jensen JTA460 Turntable
Why won't both my turntables play out of my mixer?
I am guessing but it sounds like a gorse impedance mismatch. You should never connect two outputs together unless they are specifically designed for that. Since you are listing to mono why not send each output to the Base Amp the other to the cabinet. That should resolve the problem.
Mar 29, 2013 | Numark Im1 2-channel Pro Dj Mixer With...
I am only getting one channel when recording from Numark Ion Usb turntable, using Audacity software. The software is configured for stereo, but left track is not recording (and no sound from speaker...
Set your Audacity software to STEREO MIX on the main window. Go into EDIT, Preferences and set the recording device to your sound card and the channels to 2 stereo.
Mar 07, 2011 | ION Audio iTTUSB Turntable
My Technic 1200's are only playing out of one speaker at a time.
Clearly there IS a setup issue. Take serrato out of the loop for the moment and the mixer. Plug each deck (one at a time) into a hifi with a MM Phono input. Are you getting stereo? If yes, you know the decks are ok. Now reset the mixer completey. All eqs and pans including volumes to 12 o clock position and volumes to 0.
Make sure you connect deck one to a red and white of one phono input channel. Do not use 1 channel from phono and 1 from line. Use both left and right of the phono chanels.
Ok, now hook up the mixer to the amp. Keep the x-fader on channel 1 and concentrate getting a good stereo signal from this one chanel. Now do the same for the other cahnnel.
This should hae helped you to get up an running, if not narrow down the problem.
Apr 18, 2010 | Technics SL-1200 Turntable
Technics 1210's playing out of one speaker / channel
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Mar 22, 2010 | Technics SL-1210 Turntable
ION TTSUSB10 does not record stero
I solved the problem by using www.wiki.audacityteam.org home page under the technology heading and clicking on USB turntables. The mixer had to be changed to 2 channels. (stereo)
Jan 05, 2010 | ION Audio TTUSB10 Turntable
White noise in left channel on my Vestax PMC 06 pro-a DJ mixer
try it with nothing plugged in to the inputs, if there is no noise. most likely its the turntable, cd player, or whatever the input is is the problem. or try plugging the mixer into a different area of the house/room. its like if you were to put your cell phone by a mixer, or speakers.
Jun 25, 2009 | Vestax Pmc07pro DJ Mixer System
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
SONY RCD-W100
Can you please update this with your connections. I assume that you are connecting the turntables to the mixer? Verify that the mixer is set to send out true stereo. What mixer are you using?
Note that most mixers "pan" all of the channels to the center sending out mono to the left and right. In most live shows, it makes no sense to send out true stereo. The left and right are for the speaker chains. In order to get true stereo out of the mixer, you wil need to pan the input channel for the left side all the way to the left and the input for the right channel to the right.
Dan
Mar 17, 2008 | Audio Players & Recorders
Technics SL-1200MK2 Turntable Logo
909 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
