Question about NetGear WGR614 Wireless Router
Im having a problem w/my wii
Ok, i cant seem to connect to the router w/ my wii. it can find the wireless signal but wont connect for some reason, ive tried to disconnect and reconnect and everything, im tek savvy but cant figure out what is happening, ive tried to configure settings w/ my wii, ive connected to it before, but now it wont let me
  • Anonymous Mar 26, 2009
    i have the same issue. My wii is picking up a strong signal from my netgear wgr614 wireless router, but does not allow me to connect to the internet for some reason. i also tried to reconfigure the settings and i called nintendo for help, and also called net gear with no sucess fixing the problem. I am really irritated and i feel your pain.
  • 127 Answers
Is it not getting an IP from the Router? Try resetting the router and see what that does...
Posted on Mar 26, 2008
Error code 32004
we need to start from square one... let's do this
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
Now, select "Wii Settings" to access the "Wii System Settings" menu.
Using the arrow on the right side of the screen, scroll to page two and select "Internet."
Select "Connection 1: None"
(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
Click on "Wireless Connection" and then "Search for an Access Point."
(Are you using a wired Internet connection to your Wii console?
Select "OK" and the Wii will display all the wireless networks it finds.
Select the wireless network that is yours.
If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
Select "OK," "Save Settings," and then "Yes."
The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
The connection test was not successful - If the test was not successful, you will receive an error code.
Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again.
As a last resort... 1. reset your router or 2. temporarily remove the password from your router... this way you will know where the problems lies.
Thanks
Feb 24, 2012 | Nintendo Wii Console
How do you connect the internet to the wii i have wireless in the house and it still wont connect
First, you have to go through the Internet connection setup process through the console and you've made no mention that you've attempted that so I wanted to make you aware of that. On the main menu, go to the lower left corner and click on the round Wii button. A new menu will appear with two options: Data Management and Wii Settings. Select Wii Settings. Go to the second page and choose Internet. Select Connection 1: None. Select Wireless Connection. Select Search For An Access Point. A network list will appear, select yours. You will then be prompted to enter the password/network key that you established when you set up your wireless router. The Wii will attempt to test the connection. If successful save your settings.
Second, simply because you have Wireless in the house it doesn't mean that it your wireless router has signal strength to reach the WIi. Various factors affect this including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii is too far away or, has obstacles in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles. Here is everything you need to know about connecting your Wii to the Internet.
http://www.nintendo.com/consumer/systems/wii/en_na/online.jsp
May 08, 2011 | Nintendo Wii Console
Im trying to to connect the internet on my wii like it usally has and for some reason it says on the wii settings 52031 and it dosent connect what do i do ive already tried the key and password so idk what...
Error Code 52030, 52031, 52032
It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
Change your wireless router's channel to 1 or 11
Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
Where is your wireless router located?
Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
Look for other devices
Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
WEP / WPA Troubleshooting
If you've tried the above steps to reduce interference and you're still experiencing problems, it's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console.
Apr 22, 2011 | Nintendo Wii Console
I have a wireless internet connector for my xbox and i cant seem to get it to connect to xbox live. i can get it to read that there is a connection to my computer and the signal is stong but i it wont...
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Dec 23, 2010 | Belkin N150 Enhanced Wireless Router...
Can i use a wifi adapter from computer in the wii to get my netflix to work it keeps coming say theres a connection error
Hi there, unfortunately you wont be able to use a standard wireless adaptor in your Wii purely because you cant install the software for it as PC software is completely different from the Wii software. The built in wireless should work, just that you may need to adjust some settings first. Make sure that your router signal is set to 802.11G and not 802.11N as the Wii cannot use 802.11N. Also make sure you have typed in the WEP key (usually found on a sticker on the wireless router) correctly.
Hope this helps
Dec 12, 2010 | Nintendo Wii Console
Router connection loss
Your router might have been reset and now the settings on your devices does not match that of the router. If you have wireless security enabled on your router make sure your devices are set up to match those settings.
Jan 24, 2010 | 2wire 2700HG-B Router (2700HGB)
My wi-fi keeps randomly disconnecting but is not bc a weak signal
Your card is ok. There is interference between the router and your computer.
1. The router or the PC may be "hidden" behind a metal cabinet, refrigerator, etc.
2. Move router higher
3. Microwave ovens and some cordless phones (not cellphones) that use 2.4GHz will interfere with the 2.4GHz WiFi signal.
4. Point the router antennas in-line with the direction of the PC.
5. Move the router closer to the PC.
Oct 06, 2009 | HP (319468-002) (319468002) 802.11b...
Cant connect online
make sure the wireless settings on your laptop is properly configured matching the wireless settings of your router.
Jun 29, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Netgear wg111v2 usb wireless adapter will not acquire ip address
Sorry, forgot to mention this earlier. Maybe netgear offers free Live Chat tech support. Go to their web site.
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wireless router
First make sure wireless is turned ON or enabled on the computer, then use the View Available Networks to connect to the your SSID or network name. IF you can connect to router then you should be able to surf Internet.
Jun 26, 2008 | NetGear WGR614/WG511 (wgr614nawg511nakit)...
NetGear WGR614 Wireless Router Logo
181 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
