Question about Microsoft Windows Vista Business Edition for PC
Need default admin code for kip 3100 printer.
Change c352 admin password
Mr. Gates, yes there is away to change the pw recommended you get a tech out to do it. Change admin pw not over the internet. Should have a paper work to back it up. Big time security thing Hard drive access and stuff
Feb 03, 2015 | Konica Minolta bizhub C351 All-In-One...
How do I reset the Admin password?
The default ID and password are "11111" and "x-admin" respectively. When accessing the administrator menus on the copier the code 11111 is used. I couldn't find a way to reset specifically.
I believe you should be able to access the Admin Menu by pressing the System button on the operator panel. A password is required to enter Admin Menu when Panel Lock Set is set to Enable. To Disable the Panel Lock you will need a password. The factory default panel password is 0000. Hopefully you haven't changed that. This procedure is described in the manual on pages 315 ff. I believe from there you can go in and assign a new Admin password if required.
http://www.fujixeroxprinters.com.hk/downloads/uploaded/CM215_UserGuide_Sec_c3b3.pdf
Jul 25, 2014 | Fuji Xerox® DocuPrint C3055DX Laser...
How do I set my netgear Ana 3100 to work on MacBook
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password
You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Apr 23, 2013 | Computers & Internet
How to reset Xerox Phaser 3100 to factory settings?
First you have to enable the admin mode:
press and release: (down arrow) * #
on SOS1 change the 8th bit to 1 (counting right to left)
ie: 00100001 to 10100001 {press OK to confirm}
Now the admin menus are enabled.
To <Erase all. Reset to default configuration>
press (and release): (down arrow) #7
Feb 19, 2013 | Xerox Phaser 3100MFP
Need to reset admin code for minolta di3010f
Press the utility button, then touch screen, meter count, then stop00 stop 01. Then admin input to change the password default is 00000000.
Jan 25, 2013 | Minolta Di3010f Printer
Need D-link security code to connect new Dell printer via wireless connection
You need to pull up the interface of your router to obtain the security code. Do the following steps:
1. open the command prompt on the pc
2. in the command prompt, type ipconfig
3. take note of the default gateway
4. open internet explore (or other browser) and type the default gateway in the address bar
5. the router page will be asking for a uid and pw, you should be familiar of such, if not try using admin for uid and admin for pw. These are mostly the default uid and pw for most routers.
6. once the interface of the router is pulled up, check on the wireless set-up and check on the wireless security password. That is the pw the printer is asking about.
Jul 07, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I need to put in some new account codes and delete the old ones
You need to be in the ADMIN. to change / enter codes. There is a separate code for the ADMIN. Input that code and you can change, edit, add new codes. If the ADMIN code was not ever changed then it will be the default code in the manual. Be ready because the code is not where you think in the manual. I believe it is is the setting section or check management settings. The default is usually 000000 or 111111.
Dec 18, 2008 | Sharp AR-M237 Copier
Microsoft Windows Vista Business Edition for PC Logo
920 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
