Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
Bought new last year the A-5 and seems like already after light use, is not cutting as smooth. Tried to change the blades figuring they were dull but still have the problem. The do seem to chatter a bit. Using the clip on blade assembly. I think it may just be a tension issue. How do you adjust the tension?
    Problem Solver:
Here is how I fixed my problem with the A5: There is a curved piece of metal that is meant to push the moving blade down on the stationary blade (that is attached to the handle with the two short Phillips-head screws). It fits into a slot on the moving blade. There is also a very thin nylon cover that fits on to this metal piece that goes between the blade and this piece. It adds a slight extra thickness that causes the moving blade to press harder on to the stationary blade.
It came off unnoticed when I took off the blade and went underneath the curved piece. The blade goes back together without it and there was no indication that something was missing, other than the A5 did not cut.
When I took the tool apart again under a strong light, I saw that thin nylon cover hiding in there and worked out how to assemble the tool with it in place. It started working after that.
One other thing: in the meantime I also rubbed the two blade faces against a Japanese water-stone. Extremely mild grit (4000) but maybe this removed some unwanted residue. Perhaps this also helped in getting it going.
Posted on Aug 20, 2010
  • 193 Answers
Before adjusting spring pressure check the two screws either side of the hinge *** make sure they are tight and also check to see if this component has pulled away from the body.
Posted on Apr 30, 2010
Would I be able to replace the blade on my scroll saw? How would I go about doing this?
It is possible to replace the balde on your scroll saw when it gets dull. Make sure that you do change the blade to be very careful because the new one will be very sharp. Following the instructions on this site will help you out. http://www.doityourself.com/stry/how-to-change-a-scroll-saw-blade#b
Jan 02, 2014 | Saws
I have dewalt 18 v circular saw i cut vinyl lattice once and used it on a 2x4 but it wouldnt cut it, started to cut then just stopped. is blade dull already? new saw.
a couple things to look at. Did the saw stop operating or was the blade not wanting to cut. Remove the battery and CAREFULLY feel the blade for dull or broken segments. If the blalde stopped check to make sure not a loose bolt holding it on. Did you reverse the blade for cutting the vinyl. Let me know more information and I will try and help
Feb 02, 2012 | Dewalt 18 V Cordless Circular Saw Model...
I bought a ls1016 coupond mitre saw this week. I was cutting cedar 2x6 's today and had a few kick backs. I am building my deck and do not feel safe using the saw after the kick backs. Why as this...
Sounds as if the blade is dull. Or perhaps bent. A dull or bent blade blade will 'grab' the wood, rather than cut it, resulting in binding, or kickbacks.
Solution; replace the blade with a fine-toothed, good quality blade. If the blade is new, then check that the blade is bolted tight on the arbor. If the blade is loose, it can result in kickbacks.
Also, check that all the bolts/fasteners/locking mechanisms on the saw are tight, and in good working order. Sometimes a tool new out-of-the-box will have loose screws/nuts/bolts that need to be tightened up.
Also, when cutting, use a smooth, slow, motion, being sure to give the saw the time it needs to make the cut.
Jun 19, 2011 | Makita LS1016LX 10inch DualSlide Miter Saw...
Cutting 5" log with resaw
Check the teeth tips on the right side of the blade--they may have been dulled by running into something hard--a small rock, nail, or other debris embedded in the wood. Good luck!
Feb 10, 2011 | Garden
Cutters on Elna 744 serger won't cut
is there lint or thread caught between blades preventing them from meeting?
scott
Jul 26, 2009 | Brother 929D Mechanical Sewing Machine
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
I own a Homedics ProClipper PC-400 (18 piece kit) and would like to purchase new blades for it since mine are very dull. So, where I can I get new blades and the cost of them.
Careful, blades may not be dull,most of the time it is the blade alignment that needs correcting even on used blades, been cutting and repairing clippers for over twenty years.  Repairmen dont like to tell you this.
Jan 21, 2009 | Homedics PC-400 Pro Clipper
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
272 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
