Question about Motorola Mobility A1000
Read led on the all time
A1000 around the earpiece the white round read led light on all the time why is that
May be hardware or software problem. software light this led in some cases like charging. and may can not light it down because software error. you can look after this in log files if you have any explorer in the phone memory. in ather case there is one transistor that light it up and it can be blown away.
Posted on Jul 26, 2008
Can you identify pill # H 377 ? white, round.
Im sorry but I think your either miss reading the pill specifics or they are to blurred to read clearly. Ive tried three times and there is no identification found. You might try using a magnifying tool to improve the visual.
Sep 22, 2017 | Health & Beauty
Alternating red and white blinking light on earpiece for afterglow pl-6360 then shuts off. Unit should be fully charged. Help!
Alternating red and white LED colors indicates that it is not detecting an active bluetooth connection. Use the PS3 bluetooth settings to find and reconnect the signal.
Sep 29, 2013 | PDP Pelican PDP PL6360 Sony PS3 Bluetooth...
Theres a ring around the disc
the ring is from the console being moved when the system was on you can resurface the disk or theres a disk replacement program but with that ring it most likely will not work
Nov 29, 2010 | Microsoft Xbox 360 Console
Front panel connections
Hi sjcrofts,
The most common problem for most people is knowing what wire color is positive & which wire color is negative. The colors blue, red, green, light blue, light red & light green are normally positive. The color white & black are negative. Your board uses only 2-pin connectors. The 3-pin power connector can be turned into a 2-pin connector to work with the M848ALU pins.
(Page 13, PANEL1). How to? Take the three pin connector, on the back side of the connector you'll see a small tab that holds the wire into the connector. Use a needle & pull tab up while pulling the wire out at the same time. The wire should slide out. Insert the wire back into the connector next to the other wire. You do not need to hook up the SUS led which stands for suspend.
Pin 1 is positive & the manual shows this by adding the _P = positive.
Pin 3 which is to the right of pin 1, is negative for the hard drive led. Pins 9 & 10 are not used.
Good luck sjcrofts!
Mike
Nov 30, 2008 | PC Chips M848ALU Motherboard
Changing earpiece
•First take your  device and hold it vertical.
•Looking at the earpiece that ressembles somewhat Alladin lamp, it's tip is positioned either at past 20 (for right ear) or before 20 (for left ear).
•Depending if it's one side or the other, you should turn the earpiece clockwise to 30 or counterclockwise to 30. So the "tip of the lamp", which is the ear channel of the earpiece in fact, is indeed at 30 past the hour.
•Then pull it out with a round motion downward, assuming the upper part is the blue light.
You can then change the side of the ear wire and or the earpiece for a different size supplied by RIM when you bought the device. I don't know how/where to get new earpieces. They don't seem to sell them separately...which is rather frustrating considering the price they sell this device!
Sep 03, 2008 | RIM BlackBerry 8100 HS-655 Bluetooth...
VTECH VT9121
voice message light keeps blinking
Aug 25, 2008 | Vtech 9009111 Cordless Phone
Flashing LED on the volume
i have problem with amp yamaha dsp-a1000 the led the volume it like blinks everytime is good the transistor the output is good, i dont no whats happening can u help me please
Jul 19, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Sony NW-A1000 will not play,
If you get the spinning disc error on your sony nw a1000 it means the hardrive is knackerd.
The hardrive in the sony NW A1000 is a segate ST1.2 6gb and these can be bought off ebay for around £8. If you can't find a 6gb one you can fit an 8gb hardrive BUT your NW A1000 will only use 6gb of it.
If you search on the internet you can find instructions on how to remove the back cover of your NW A1000 which is very easy to do! You then unplug the hardrive (be very careful!) and replace it with the new seagate hardrive. Turn the NW A1000 on and go to the home menu, select "settings", then select "intialize disc" and it will format your new hardrive so that it can work with NW A1000.
Jul 02, 2008 | Sony NW-A1000 MP3 Player
Motorola Mobility A1000 Logo
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
