Question about Philips Magnavox 15MF400T 15 in. LCD Television
Magnavox 15MF400T/37 Channel chosen is not correct channel
For some reason unkown to me, now when I choose Channel 4, instead of bringing up the network that is Channel 4, it brings up Channel 20. Channel 20 is still correct. Channel 4 still says it's Channel 4 when you click on Display. What happened? What caused it to swap or change? Other TVs in the house are still correct, so it is not caused by Verizon.
    Genius:
  • Philips Master
  • 1,689 Answers
Check the instrucitons to verify if the channel table is pre-setable to designate your own numbers.
Most TV sets have an autoprogramming for the channels. Look in the menu for the auto programming and let the set re-program the channels if your set has that option. This feature will re-program the channals, and re-set their defaults.
If the channels are not able to be pre-setable to a custom table, then this indicates that there is a pre-scaling fault in the tuner or in the uPC. In this case, the set will need service.
Jerry G.
Posted on May 17, 2008
Magnavox 15mf400t 37
Check the other sources first - AV, scart, hdmi, etc. If you get the same result your main AV board needs replacing or repairing.
Jun 17, 2013 | Televison & Video
I NEED A POWER SUPPLY AND CORD FOR A MAGNAVOX 15' LCD TV MODEL NUMBER 15MF400T/37 POWER RATING 12V 3.5A
Either you can get this universal type available inthe market in any electronic spares store or it is easy too make one by yourself if you are familiar with electroncis.
All you need is a mains transformer with secondary voltage at 12 volt and 4 amps capacity, use a bridge rectifier , good storage capacitor of about 4700mfd/25 volts and if possible use a 12 V regulator so that the power is smooth, regulated and protected..
Sep 24, 2010 | Philips Magnavox 15MF400T 15 in. LCD...
Can i get channels using a digital antenna with my magnavox mf400t/37?
yes there is no such thing as a digital arial an arial is an arial there is no diverence other than price
Jun 12, 2010 | Philips Magnavox 15MF400T 15 in. LCD...
TV stuck on one channel will not change? help
Go to http://www.m4c.magnavox.com/ then click on product support, select your model, then click on software and downloads. Download the latest software release for your tv and follow the instructions for installing the software.
Aug 09, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
MAGNAVOX 17MF200V
Could your remote possibly need new batteries? Sometimes remotes act erratic when in need of them. Check that out and see if that is the reason for your problem. Luck!
~ KT
Jan 10, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Help
try going into menu. find parental control and turn it off
Dec 01, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Some channels have no color or sound
once a signal falls below a certain threshold the color will be lost.
some sets are more sensitive to this loss.
if you see static in the picture on any of the channels then the cable is leaking and needs replaced /tightened.
if a local air broadcast is leaking into a same cable channel on the cable you will get poor to no reception on that channel.
for example : he we have a local channel 7 on the air.
if i tune to cable 7 and see a weak or distorted pic then the cable is leaking and needs replaced.
May 04, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Philips Magnavox 15MF400T 15 in. LCD Television Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
