Question about Craftsman 25cc Gas Line Trimmer
Can't find my manual and all the line is gone off the Craftsman trimmer. Had the trimmer for a long time but was never the one to replace the line. I know at one time I bought these replacement spools at Sears but I can't figure out how to get the head off to replace the trim line. HELP!
  • 398 Answers
SOURCE: Need to replace entire head of Craftsman Bushwacker
there should be a little alignment hole where you can stick a small screwdriver thru to hold it from spinning then turn clockwise(its reverse thread). let me know if there isnt an alignment hole
Posted on Mar 26, 2009
slohry
  • 87 Answers
SOURCE: Ignition module to flywheel gap for CRAFTSMAN line trimmer
The correct gap is .010
Posted on Apr 12, 2009
erickg
  • 116 Answers
SOURCE: REplacing the pulling cord on a gas trimmer
those are usaully under your pull start cover and if its broke you can buy a new rope but if its broke near handle i would open it and retie it to save ya money. but remember to wind spring a little to keep tension on it before pushing it through the hole for handle.
Posted on Apr 17, 2009
  • 46 Answers
SOURCE: change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
Posted on May 31, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
Craftsman owner manuals
If you go to searspartsdirect.com and put the model number in it will show you a diagram and on the page is a offering for the owners manual.
Jun 26, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
How to change trimmer line 32 cc craftsman weed ****
Input the model number of your trimmer here and download an owner's manual. The manual will have detailed instructions on how to change the trimmer line.
http://www.managemylife.com/mmh/owner_manuals
May 01, 2011 | Craftsman Garden
I have a 25cc gas trimmer. It leaks a little gas from the clear, flexible gas supply line(s). Is it possible (practical ?) to repair a leak in the gas line(s) ? Can the lines be replaced...
They get replaced all the time. The "new" gas with ethanol tends to deteriorate them more quickly nowadays. Small engine repair shop has the fuel lines you need. Repairing them is not done.
If you have the Craftsman trimmer, just ask for about a foot or two of each of the 2 different size lines. They are called "Tygon" fuel lines. Runs about a dollar/foot for the stuff.
Nov 12, 2010 | Craftsman Garden
Machine will start but won't stay running. give some gas and it runs for a couple of seconds and then dies. i did replace the spark plug but it is doing the same thing. it is a 25cc craftsman weedwacker...
I had a similar problem and it was simple to fix. I hope yours is the same. The line going into the gas tank is not far enough down in the tank.Once you prime it with the primer bulb , it will run till that gas is gone. No fuel from the tank is getting to the carburetor. If you've replaced the fuel lines recently, this may be your problem. If not, try cleaning the fuel tank and the carburetor. Hope this helps.
Sep 08, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
Jun 12, 2010 | RTO Weed Eater Hedge Trimmer 20cc,...
Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
613 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
