Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Electric black & decker mower seized , where can i get service
SOURCE: black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
Posted on May 23, 2008
  • 313 Answers
SOURCE: WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Posted on May 31, 2008
jmgldsmth
  • 1869 Answers
SOURCE: electric lawn mower slowed down then stopped working?
The carbon brushes on your mower have worn and, need to be replaced; order them from black & decker
Posted on May 21, 2009
  • 4 Answers
SOURCE: Black and Decker Electric Lawn Mower MM850 wiring diagram
I have repaired mines. It was found in the trash dump, just before street curb side trash collection. It is a very sophisticated lawn mower. It taken me a month to restore it. The problem is the housing is poor design and does not hold the pin switch securely. This is not a simple on/off switch. It is switch module with two momentary switches built in to it to work simultaneously. The hot is a normally open momentary switch and the neutral is a normally closed momentary switch. Two things must occurred simultaneously for the lawn mower to work. The AC hot has to close and the neutral to open. This is a split phase AC motor. The switch has four connectors to it. The first two has black wires to it, for the hot, that is normally open. The second two has a white wire and red wire to it for the motor's start up winding. The orange connects with the plug's white, neutral. A new substitute switch will be two individual momentary switch, one for the two black wires will be normally open and the two for the red and white wires from the motor start coil will be normally close. It will take two fingers to operate the lawn mower. I recommend you to buy a new and each switch from Black and Decker.
The problem with the system is not the switch, but the poorly designed switch box housing. Often, there is nothing wrong with the switch. I tested mines and it works fine. The problem is the switch box housing does not keep the switch in the correct position for the higher tension spring lever to press against it to operate. I use small washers to stack between the rear of the switch inside and reassembled the switch box upside down by turning the handle upside down, so the washers and switch do not fall out. Once I am finished assembling the switch box and position it on the handle, then I position the handle back to the normal top side and attach the handle back to the lawn mower. I am finished.
http://en.wikipedia.org/wiki/AC_motor#Split-phase_induction_motor
"Split Phase Motors
Split phase ac motors are widely used for low power applications as for example in oil burners, furnace blowers, garage door openers and major appliances. Such motors employ separate run and start windings connected in parallel across the acpower source. When the motor is initially energized both windings are energized, and when the rotor speed reaches about eighty-five percent of the normal running speed the start winding is disconnected from the circuit. Various devices are utilized forthis latter purpose and include centrifugal switches and current and voltage relays.
A problem which is characteristic of these motors is that they have a relatively short operating life. The principal reason for this is the failure of the switching devices used to cut out the start windings when the rotors approach the normalrunning speeds.Failure of these switching devices in turn cause the start windings to burn out.
One of the reasons for the failure of these switching devices is the high currents which they are carrying at the time the contacts open. Attempts to increase contact life by use of improved designs and materials have not been altogethersuccessful. Another disadvantage associated with these switching devices is that they are necessarily quite large and occupy a substantial space in the motor housing." -from another web site.
Posted on Sep 08, 2009
  • 23 Answers
SOURCE: WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER MM 850
looking down at the terminals, rotate push-button to the right. the wiring sequence is R, W at the top, then Black (in, from power source) , Black (out, to motor).
Posted on Sep 27, 2009
Black and decker electric mower hums but blade does not turn. appears the brake is not releasing for the blade.
Something has the motor unable to turn. Do not turn on till you locate the source of the problem lest you burn it out.
Aug 02, 2016 | Black and Decker USA Black & Decker MM1800...
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
Replacement grass catch bag for Black & Decker mm600 electric mower
It appears that you will need to contact the service center as in your parts diagram, the bag is not listed. A mulching blade is listed, which doesn't require the use of a bag.
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=MM600&selectedType=4882
May 07, 2011 | Black & Decker 19" Electric Lawnhog...
Two-year-old Black & Decker 19"
if its not in the cord. it may be the brushes in the motor. if they are worn down and not hitting armature. motor will not run. good-day !
May 05, 2011 | Black & Decker 19" Electric Lawnhog...
Electric lawn mower slowed down then stopped working?
May 21, 2009 | Black & Decker 19" Electric Lawnhog...
Replacement batterys for cmm1200 black&decker electric mower
You can find replacement batteries on amazon, click here and take a look: Amazon com Black and Decker 24 0 Volt Lawn Mower Battery 90508011. I hope this was helpful. Cheers
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
201 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
