Question about GE Dishwashers
GE Profile Dishwasher won't turn on
Our 2 1/2 yr old GE Profile Dishwasher (Model# PDW9280NSS) will not turn on. About a month ago it stopped in the middle of a wash cycle. It wouldn't start again so my wife unplugged it and plugged it back in again and restarted it. It stopped again while filling with water and wouldn't start again. I ordered a new control module and installed it and saw some flashing of the key pad but it still wouldn't work. I then ordered a new touchpad and installed it but it still won't work. It is now completely dead, no lights on at all.
  • reynolds_hb Jun 12, 2010
    I would have never guessed the problem on my own and was skeptical right up until I found the expert was right on. Thanks for your help!!
  • 1,543 Answers
OK, this may sound silly, but check this out: I ran into a similar situation, and found that the electrical connections, where the incomming power connects to the dishwasher, were bad. The wire nuts were not making good solid contact. When they heated up a bit, the wire momentarily broke contact. Check it by getting to the connections behind the toe kick panel, then holding the twist on wire connectors (one at a time) and give a moderate pull on each individual wire to make sure none come loose. This may not be your problem, but it may be. It is the first place to check after you, make sure you do have power to the dishwasher. (no tripped breaker, etc.)
Posted on Jun 12, 2010
    That was the problem, but it was even worse. The wire nuts had melted and were charred. It looked like it started with the hot wire nut but all three were charred. Any idea what would have caused that. Is it just an extreme case of what you mentioned.
    When I installed new wire nuts I used some of the sealer that I've used on outdoor connections just in case water was getting into that area when we open the dishwasher door.
10-yr old GE Profile dishwasher...lately there's been detergent left in the cup, and lots of items come out dirty...plastic, ceramic, etc. I've cleaned/rinsed the sprayer and filter, but it doesn't he
Check if the water is getting heated in the dishwasher. Most likely water temperature if not adeqaute will not fully use the detergent and cause dirty dishes. This could be caused by heater which is failing.
Apr 19, 2014 | GE 24 in. Profile PDW7800 Built-in...
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
Had the power go out in our house. When power
hello. thanks for choosing fixya. honestly I do recommend that you get a new one. By the time you get your current one repaired you will have almost as much money in it as a new one and you will miss out on lots of things the new ones offer now such as: much more efficient use of power, much more efficient use of water, much quieter. and a much better wash. Regards, J.
Nov 05, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE Dishwasher model PDW8200J03BB stopped draining. Removed the drain pump, checked with Voltmeter and there is resistance on ohms X10 of about 3. The flap is in place so water isn't shooting back into the...
clear the line from the air gap to the drain,, if the rest is clear the only thing it can be is the propellers on the pump, i which case you will need to change the pump
Jun 06, 2009 | GE 25 in. Profile PDW8200J Built-in...
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE side by Side - dead, again
check defrost timer . plug in and turn timer manualy and see if unit starts running. This means it was in a defrost mode which occurs twice daily.
Feb 21, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Need a diagram for the kenmore dishwasher model 665.16645890
I have GE Dishwasher (model no:GSD1100G02),and for the last few month I was not able close the main detergent cup cap(it is coming back to full open position,even after keeping the CAP turned all the way to a closing postion)
I have called the GE spare parts division,and obtained the New detergent cup cap,and when I tried to remove the old one,inorder to replace with the new one,I was not able remove old one.
Please help me how to remove the old main detergent cup cap,and replace with a new one.
Hope I will hear from you soon in this regard.
Murthy Pillutla
Home Ph:630-428-3277
Cell:484-919-3653
Jun 14, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
GE profile Dishwasher less then 1 yr old
There is a drain hole in the side (probably) of the garbage disposal which must be manually "punched out" in order to attach the hose from the dishwasher to the garbage disposal and thereby allow for draining. Think of this as the dishwasher piggy-backing on the existing drain system for the sink/garbage disposal. I am certain this will solve your problem.
Sep 28, 2007 | GE 24 in. Profile PDW7800 Built-in...
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Dishwashers Logo
218 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
