Question about Craftsman 22" Gas Hedge Trimmer
Blades won't operate....motor is running - 18" gas hedge trimmer
  • 29 Answers
Centrifical clutch oily or slipping.
Posted on May 01, 2010
Have a echo 150 gas hedge trimmer motor runs blades don't move what could cause that
Inside the bottom panel, is where the grease etc is... you can take the cover off to make sure it's greased up inside, if it's running and the blades aren't moving when you throttle it, then they can be siezed , or the gear under the panel is off line or broke.
Aug 16, 2015 | Echo Garden
I have a petrol hedge trimmer TRY26PHTA. The engine will start fine but the blades will not move
If the engine starts 'fine" then it has not seized.
Many, if not most, hedge trimmers are , for safety, equipped with a "CENTRIFUGAL CLUTCH" between the engine and the blade to prevent blade operation unless the engine is at full RPM.
IF your machine is so equipped, it's possible that the clutch is worn and slipping so badly that the blade can't move.
Jun 11, 2014 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Stihl HS45 hedge trimmer runs fine, blades move well, does not appear to cut hedge - what could be the problem ?
Dull blades! Lol, or they're not meeting eachother on each reciprocating stroke so there is no shearing action, much like a pair of scissors. Check to see if the blade bolts are too loose or is the blades are warped or if the cutting edges are simply too dull
Sep 24, 2013 | American Gardener Rh25 18" Readyhedger...
Trimming blades locked but motor still runs
The gear drive that operates the blades is defective. Contact your local parts supplier for parts prices or contact Searsdirect.com
Apr 09, 2012 | Echo Gas 20 In Bar Double Reciprocating...
Blades will not operate when engine is running on my HS 81-R hedge trimmer
check the gear box where the motor meets the drive
Mar 29, 2012 | Garden
Weedeater Excaliber Gas Hedge Trimmer. Is it possible to sharpen these blades? If yes, do you know the procedure?
You should be able to sharpen your hedge trimmer blades. There is a good video on how to sharpen hedge trimmer blades on youtube by ereplacementparts. He explains how to do it with a file or a grinder.
Aug 24, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
My hedge trimmer blades do not move when I turn it on
Check the power wires that connect to the motor. My 18 inch B&D hedge trimmers both had loose wires at the motor that had to be re-soldered. You will need to open the trimmer casing to get to the loose wires, if that is the problem.
Jul 09, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Hedge trimmer blade not moving
I have a Troy-Bilt gas powered hedge trimmer. My blades would not move. After tearing it apart, I found that there were some spacers under the 5 or 6 screws along the blades. These spacers are steel and designed so that you don't overtighten the screws. However, around those steel spacers, there is a teflon type material that makes the oval shape of the slot. That teflon had fallen apart and lodged so that the blades would not move. I removed the teflon and put the spacers back in and it now works fine. There is a little play between the spacer and the edge of the slot and it will probably eventually wear out but at least I got a few more cuttings off of it.
Jul 04, 2009 | Black & Decker Black Decker 16" Hedge...
Electric Hedge trimmer will not cut
more than likely it damaged the inner gears or drive pins that make the blades reciprocate and need replaced. if you would like instructions to repair it yourself i will send you them or you can take it to a service center.
Sep 08, 2008 | Electric Hedge Trimmer, 18"
Craftsman 22" Gas Hedge Trimmer Logo
375 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
