I can't get machine to print on envelopes. - Office Equipment & Supplies
  • 6,993 Answers
have you been printing on an envelope before or is this your first time of trying to print on an envelope?
Now, I am assuming this is your first time you are printing on an envelope, so I would give you the basics of how to print on an envelope:
  1. Open Microsoft Word. On Macs, this will be a blue "W" shaped icon on the bottom. In Windows, click "Start" then "Program Files" and you will find it under Microsoft Office. Once in Microsoft Word, select "Envelopes" from the tools menu.
  2. Type the delivery address. Type it out in the standard format. Choose the layout and font by clicking the buttons.
  3. Type the return address. Do this the same way as the delivery address.
  4. Set up your printer by clicking "Page Setup." Under "Paper Size," select the size of your envelope. Under "Orientation," select the icon that shows a page being printed lengthwise or select an envelope preset if one exists.
  5. Select "Print Preview." Once you have clicked "OK" you should see your text. Under "File," select "Print "review." Make sure that the page appears correctly.
  6. Insert your envelope. Take out any other paper and load the envelope into the tray. There should be a paper size selector. This is usually a sliding piece on the paper feeder. Place your envelope with one side touching the edge and slide the slider to meet the other side.
  7. Click "Print" on your computer.
You can also visit the below link as it might be of help:
http://www.ehow.com/how_4710935_print-envelope-microsoft-word.html
Good luck.
Posted on Apr 30, 2010
How do I print on A4 envelope with Canon ir 4080i photocopy/printer machine?
in printer just put your envelope portrait position, then set your paper setting into envelope size in your laptop or PC and just print it
in photocopy machine just adjust the input tray into envelope size than put envelope printed face up, and just print it
Feb 18, 2015 | Canon Office Equipment & Supplies
How to load envelopes in a canon mg3250 printer
Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif You can only print on envelopes with the computer.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive Prepare envelopes.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Press down on all four corners and edges of the envelopes to flatten them.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the corner of the envelope flap is folded, flatten it.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm). Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides. (5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Be sure to open the paper output tray when printing. If not open, the machine cannot start printing. After loading envelopes
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image003.gif Select the size and type of the loaded envelopes on the print settings screen of the printer driver. You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
Nov 13, 2014 | Canon PIXMA MG3250 All-in-One Inkjet...
Sharp MX-3501N will not accept envelopes
here is a walkthrough for printing on envelopes. basically you have to set the machine for envelopes then set your print job for envelopes.
How To Print on Envelopes or Labels on Sharp Printer
Copier Collin Houston TX Copier and Imaging Expert
Jun 30, 2014 | Sharp MX-3501N All-In-One Printer
How do I print envelopes in the printer Samsung SCX 4824fn? thanks
• Successful printing on envelopes depends upon the
quality of the envelopes. When selecting envelopes,
consider the following factors:
- Weight: The weight of the envelope paper should
not exceed 90 g/m2 or jamming may occur.
- Construction: Prior to printing, envelopes should
lie flat with less than 6 mm curl, and should not
contain air.
- Condition: Envelopes should not be wrinkled,
nicked, or otherwise damaged.
- Temperature: You should use envelopes that are
compatible with the heat and pressure of the
machine during operation.
• Use only well-constructed envelopes with sharp and
well creased folds.
• Do not use stamped envelopes.
• Do not use envelopes with clasps, snaps, windows,
coated lining, self-adhesive seals, or other synthetic
materials.
• Do not use damaged or poorly made envelopes.
• Be sure the seam at both ends of the envelope
extends all the way to the corner of the envelope.
Envelopes with a peel-off adhesive strip or with
more than one flap that folds over to seal must use
adhesives compatible with the machine's fusing
temperature for 0.1 second. Check your machine's
specification to view the fusing temperature, see
page 82. The extra flaps and strips might cause
wrinkling, creasing, or jams, and may even damage
the fuser.
• For the best print quality, position margins no closer
than 15 mm from the edges of the envelope.
• Avoid printing over the area where the envelope's
seams meet.
Place the side to be printed facing up.
Envelope Preprinted paper Transparency
Punched paper Card stock Letterhead paper
Labe
open the direct paper try on top of your A4 paper try by pushing it!
Apr 22, 2011 | Samsung SCX-4828FN All-In-One Laser...
I use a Dell 3110 cn printer. There were black splotches whenever I printed envelopes.I had a serviceman look at it to no avail so I changed the black toner cartridge. I am now getting blue splotches. ...
when you print envelopes you have to choose the envelopes in the printer settings then only machine knows that envelope is printing. when you don't select envelope in printer settings when you sent a print, the printer knows the a normal paper is coming through. the difference is that the envelope is a bit thick the normal paper. when envelope is selected in printer properties then the printer adjusts its settings to print on envelopes.
Jan 06, 2011 | Dell 3110cn Laser Printer
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
HOW DO I PRINT AN ENVELOPE ON THE IMAGE RUNNER 3025
On right sideway of machine is door, on this door is bypass tray wich you need to open.Open and place envelopes on it, use paper side guidances, envelope must be print side face down.
"Tell" the machine wich is format, type and confirm.
Under printer driver set according settings.
May 14, 2010 | Canon ImageRunner 3025 Black and White...
Lanier LD135. How do I program it to print
Envelopes thru bypass only....once they are set youl need to set the bypass to envelopes at the machine either thru user tools or by pressing bypass then the # key and selecting envelope or custom size and entering the size of your envelopes.
Back at the computer go into print proprties and select paper souce bypass the printdriver will use the machine settings unless ou tell it otherwise
Feb 24, 2010 | Lanier Office Equipment & Supplies
Unable to print #10 envelopes on my Xerox WorkCentre 7675... I am using Microsoft Word and selecting the Bypass tray, but I'm still unable to print on these envelopes. Are there any other solutions?
Although you can lie to the 76XX series machine and get it to print on envelopes, the machine clearly shows that it does not take envelopes on the tray pictures. "Only C4 (229 x 324 mm / 9 x 12.7 in.) and C5 (102 x 229 mm / 4 x 8.7 in.) sized envelopes can be used with this printer; Number 10 envelopes are not supported. Attempting to use any other envelope sizes in this printer could result in jams. or damage to the printer. Do not use envelopes other than what is supported. "
Insert them Face up, flaps closed, leading edge to the right. When it asks, tell it envelopes, and give the size.
In the Envelopes section, under Mailings, Options, choose face up, and the 5th picture. It should work, but the envelopes sure get wrinkled.
Jul 31, 2009 | Xerox Office Equipment & Supplies
Printer not printing address on envelope
In Print Options, go to Preferences- - - - ->Paper Type- - - - ->Select the size of your Envelop- - - -Apply.
You will be able to print on Envelop after this.
Apr 15, 2009 | HP Deskjet 6940 InkJet Printer
48 people viewed this question
jasbo
jasbo
