Question about Creative Labs Zen MicroPhoto MP3 Player
My zen micro photo doesn't seem to have a reset "hole" below the power switch
I think to reset mine, I take the battery out and then hold the swith on while putting the batttery back in. If I am incorrect and there is another way to reset, please advise me. Thank you very much for your time!
    President:
  • 4,402 Answers
Your correct, i think all you really have to do is take out the battery and have nothing on the usb port.
Posted on Mar 26, 2008
SOURCE:
My Zen seems to be totally dead after loading it with mp3 tracks. I've recharged it to no avail, it won't switch on or reset, and it is not recognised by my computer when connecting via a USB...
hi your not the only one i got mine for my birthday 8 weeks ago and now it dont work its like its dead this zen v plus to is like not the best thing to have all i see is people like me having some sort of prob with it
Sep 20, 2011 | Creative Labs ZEN V Plus MP3 Player
How do i reset my zen?
1. Find the reset hole on the side of the player, just below the power/hold switch. DO NOT MISTAKE IT FOR THE MICROPHONE HOLE AT THE TOP.
2. Push a paper clip in the hole, and the player should automatically shut off.
Regards,
Jeep Brainy
Aug 12, 2009 | Creative Labs ZEN V Plus MP3 Player
My zen V plus is stuck in recovery mode. i cannot select an option or shut it off. how do i reset it?
try this: Find the reset hole on the side of the player just below the power/hold switch. Please do not mistake it for the microphone hole at the top. Then push a paper clip or something similar in the hole, and the player should automatically shut off. If your player does not shut off, you will have to wait for the battery to run out and die, but usually the reset hole works.
Aug 05, 2009 | Creative Labs ZEN V Plus MP3 Player
My Zen V Plus mp3 froze on me how do i reset it
3. If your player does not shut off, you must wait for the battery to die, but mostly, the reset hole works.
Sep 24, 2008 | Audio Players & Recorders
Creatinve Zen 4GB video - Photos, not turning on.
Initially:
  1. try a reset: Insert a paperclip into the reset hole at the bottom of the Vision
  2. Or, try running off mains power, not battery (in case you have a dead battery)
  3. If you're able to get in to the system, try going into Recovery Mode
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 31, 2008 | Creative Labs Zen Micro MP3 Player
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision won't turn on
Q. Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
also try this if above doesnt work
Feb 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Jxd i pod not working
Jan 30, 2008 | Creative Labs Zen Micro MP3 Player
My zen is freezeing
1. I'd try a system clean up first (instructions below)
2. definitely upgrade your firmware (http://us.creative.com/support/downloads/)
3. If all else fails, back up all your music on your PC and format it (instructions below)
.... from Creative's site
Reset, Format or Clean Up a Zen Vision:M If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
Press on the Menu/Back button on your player, and select System, and then Reset.
To Format or Clean Up Zen Vision:M
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off. If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. vision_m_reset1.jpg
  4. Release the Power switch when the Creative logo appears. The Recovery Mode appears:
    • Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
    • Format All (Formats the players hard disk - Note: all contents will be lost)
    • Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
    • Reboot (Reboots the device).
  5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
Jan 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Zen MicroPhoto MP3 Player Logo
64 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
