Question about Weber Genesis Silver B Grill
Possible gas leak where tube exits propane tank recommendations
    Guru:
  • 1,051 Answers
If your referring to the valve assembly that was attached to the tank when purchased, it is usually soldered or welded in place to prevent removal. A leak there indicates a defective tank and it should be replaced for a new one. If the leak is at one of the fittings you use to connect the tank to the grill try disconnecting and then reconnecting. While disconnected check the small rubber O-ring, making sure it has no fine cracks and doesn't appear dried out. If it doesn't look good you can get a new one at most hardware stores.
Posted on Apr 30, 2010
Way is my machine using to much propane
Are you smelling gas around the grill or tank? Fill a spray bottle with soapy water, slowly turn on the tank valve, and check for leaks at the tank valve, hose, regulator, as well as each gas valve (remove the knobs first). If no smell or leak is found, check your burners to see if they are burning mostly blue. If they are lazy yellow, they could be dirty or partially clogged and require cleaning; or possibly rusted through and need replaced.. If you do have blue flames, consider turning down the burners for a reduced flame and see if that helps.
Apr 30, 2015 | Grilling
Duotherm dowmflow propane furnace the pilot keeps blowing out
There should be an access hole in the gas valve near the pilot gas tube entrance to readjust the pilot pressure. There may also be a small regulator in the tube for adjusting pressure. But if it was OK for years and all of a sudden just started blowing out, its probably a dirty pilot assembly. Also, if you have changed locations of your propane tank to a cooler location, ambient temperatures will lower the pressure of the propane. If your not familiar enough to remove, clean and replace the pilot assembly, you should call a trustworthy tech. There is a definite reason it started blowing out. All possibilities should eliminated before raising pressure. ALWAYS be careful with propane! Unlike natural gas, it is heavier than air and will collect in the tray under the burners and explode when a flame is established. Propane explosions are common. Be VERY careful!!!!!!!
Nov 05, 2013 | Heating & Cooling
Last year we had all the siding on our tv, trailer, replaced due to hail damage. When we finally got our trailer back from the rv repair shop we have had nothing but problems with our Atwood hot water tank...
Immediate danger!
You have a gas leak.
Propane is heavier than air and will settle on the floor.
The floor can be covered and ignite and you will not smell it while standing or sitting or laying in bed.
Absolutely open the door and leave trailer. Turn off the gas to the heater if the shut-off is outside.
Possibly you have a bad gas control valve. This should be repaired professionally.
Aug 08, 2012 | Water Heaters
Hi, I have a scanner cause engine light is on, shows vacuum leak large. tried new gas cap, cleaned filler tube where gas cap contacts, replaced a plastic tube from valve cover to air filter hose. tried to...
what code is it?po440,p0455?If it is one of those codes it means you have a large evap system leak not a vacuum leak by the engine.the evap leak is most likely a inop vent valve or a fuel cap not properly sealing.
Apr 13, 2011 | 2005 Chevrolet Uplander
I have a gas leak coming from grill, gas is turned off. Is this a common problem and is it a simple fix?
If you still have a leak when the gas tank is turned OFF, it's not the grill leaking it's the propane tank valve leaking. Carefully disconnect the hose from the grill (No Smoking) and move the tank as far from the house as you can, into an open area, where the gas can dissipate. Propane gas is heavier than air, it doesn't rise it falls. If after doing this and you still smell gas leaking from the tank, contact your local fire department.
Apr 06, 2011 | Broilmaster P4BL Gas
Propane was leaking between tank and regulator on my BBQ. Replaced with three new regulators and two new propane tanks but still get strong hissing from vent hole and strong smell of propane when I open...
I would recommend you take the regulator, hose and 20# cylinder to your local propane co and have them check it out for you. Or if possible, just load the entire bbg in a truck and bring it all to them. Call first to schedule a time that can look at it. If you replaced the tank and the regulator, my guess is that you probably have a cracked fitting or the fitting is missing an integral part that seals it to the tank. Douglas
Jul 29, 2010 | Char-Broil Grilling
Grill does not get hot. I have a fresh bottle of propane. Hose is not kinked. Grill is maybe 6 - 10 years old.
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Jun 15, 2010 | Weber Genesis Silver B Grill
I have a Thermos 461262407 Propane Grill. It will not light, gets good ignition, and I just got a filled propane tank. I don't hear the sound of gas entering the tubes when I turn on the knob. Is it...
Hello, here is a check list for your most common gas grill lighting problems: Hopefully one will solve it for you.
1) Check your tank. Is it empty or nearly empty? The tare weight (T.W.) of your cylinder is stamped on the collar. This is the weight of your empty cylinder, usually around 18 lbs. Weigh it on your bathroom scale2_bing.gif. Propane weighs 4.25 lbs/gal. If it weighs around 20 lbs or less - Refill it. If not, go to #2.
2) Make sure you didn't turn the gas tank valve on too fast. Some gas hoses have a built-in excess flow valve that stops the flow of gas to a trickle if opened too fast. Close the tank valve and let sit for a few minutes. Or just disconnect it and reconnect it. Turn the tank valve very slowly and then try lighting it again. If it doesn't help, go to #3.
3) Is the igniter sparking? Some are battery2_bing.gif powered-check the battery or replace it. If you have a standard push button piezzo igniter or a rotary style2_bing.gif igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. If not, go to #4.
4) You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
5) If none of these resolve the issues you are having, it is also possible you have a faulty or defective regulator, which may mean replacement. If the pressure still seems too low and none of the above has helped, and you have a silver/gray regulator; many have an adjustment screw on the top center of the diaphragm. Remove the outer cap and turn the inside screw clockwise in 1/4 turns to increase the pressure until the desired flame size is accomplished. Flames should be as blue as possible, but will burn orange if there is food or drippings on it. Yellow flames are not good, and will soot up everything and not cook as hot as blue flames do. Yellow flames could mean you do not have the right air shutter adjustment, clogged burners, or possibly defective burners, as mentioned above in #4.
6) Also make sure you have the hose connection tightened snugly to the propane tank valve to ensure the inner valve seat is fully depressed allowing gas to exit fully without any restriction. The black plastic female fitting should be hand tightened only. Older versions that use a left-hand male brass POL valve, requires a 7/8 open end wrench or adjustable wrench to tighten.
Hope this helps! Good luck in your trouble shooting! Douglas
May 30, 2010 | Thermos Stainless Steel Gas Grill
Have a large mobile propane grill with burner problems
Ok, here is a check list for your most common gas grill lighting problems:
May 19, 2010 | Big Green Egg Extra Large - XLHD...
Fuel vent tube is leaking gas. The tube comes out of the bottom of the tank. When I blow air into the tube it doesn't bubble the gas in the tank and it sounds like the air is right there next to the filler...
Very possibly could have a hole, or rusted off of it's perch. Get a mirror and a flash light, and when the gas gets low enough, take a look in the tank.
Aug 04, 2009 | 1997 Suzuki VZ 800 Marauder
Weber Genesis Silver B Grill Logo
107 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
