I'm using the Kodak Home Center to scan a hand-written poem and drawing (on one page). It is scanning fine, a get the expected preview. Now, I want to send this scan to my documents file. My problem is that after looking at the various editing options, I'm finding nowhere to indicate that I am done editing, and no finish screen comes up; so I'm stuck there. The query function of the Home Center software does not say how to indentify that editing is done.
  • 1 more comment
  • dwhorton494 Apr 30, 2010
    I will open and follow the tutorial. Then I will let you know that it worked, or ask additional question
    it worked; I'm happy person again. thanks
    thanks; ekse most helpful, am happy again
  • 13,433 Answers
Open up this interactive tutorial
http://www.kodak.com/global/en/service/tutorials/AiOPrinters/ENG_KHC_MAIN_v21.htm
On the left side click on Basic Scanning. Follow the tutorial and in your case you would take black and white document or picture.
Then scan. Once you have scanned what you wanted, click on Next.
On the finish page you have the option to SAVE TO FILE, from there you can save the scanned files into your my documents folder, to do that click on the Browse, then open your my documents, and click ok, then name your file and click SAVE.
Posted on Apr 30, 2010
  • Ekse Apr 30, 2010
    Editing can be done after, with another software, so you can skip the edit in the home center and edit it later if needed.
  • Ekse Apr 30, 2010
    No problem! Go ahead and click on the accept button.
I have a Kodak esp 7250 printer that will only scan a picture from my laptop runing Windows 7 using older AIO Home center software (5.4.vs my desktop computer running Windows Vista that rescently had the...
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
How to scan more than 1 page at a time
ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. Open HP Solution Center with one of the following methods:
  1. Click Start , click All Programs , click the HP folder, and then click HP Solution Center
  • Double-click the HP Solution Center icon on your desktop. A "Scanning from..." screen displays to prompt for scan settings. If this settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. Click Scan Settings , and then click the appropriate option from the popup menu: Scan Picture Settings or Scan Document Settings .
    3. Select the check box, Prompt for settings at the time of scan , and then click OK .
    4. Click Home , and then start the scan again.On the "Scanning from..." screen, click the appropriate option under "Scan Shortcuts" on the left. Each shortcut has a default group of settings that display when you click it.
  • Click Change Settings , and then read through the drop-down menu choices for all of the settings for the shortcut, adjusting any settings as necessary. Also click the Advanced Picture Settings button and the Save to file Save Options button to view your choices and make any changes. Important : HP Solution Center versions and options vary, depending on your printer. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  • Click Scan . The preview screen might display, if you selected the option to show a preview. Use the options on the preview screen to make any desired adjustments before you finish the scan.
  • After the scan completes, it goes to the destination that you specified in the settings.
  • Scan Button: HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. Important: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want. NOTE: The steps to set up the scan button on your printer can vary depending on your printer model, and the version of software that is installed. For specific instructions, click the Help button on the home screen or settings screens in HP Solution Center.
    Dec 04, 2010 | HP Officejet 6310 All-In-One InkJet...
    I have a Kodak AIO 5 printer and Windows 7. I
    This is easily accomplished using Kodak AIO Home Center v5.3:
    Scanning documents from Home Center
    1 On the main screen, click Scan Documents and Pictures.
    2 Place your original document face down on the scanner glass.
    3 Select Document.
    4 Select the type of document you are scanning.
    5 Select a Resolution for your scan from the drop-down list.
    6 Select Perfect Page Technology to automatically correct imperfections in the scan.
    7 Select Next.
    8 On the Edit screen, edit each image as needed.
    9 Click Next.
    10 Select Save to File, then select Save As (pdf or rtf), Then Save.
    11 Select Done to return to the main menu.
    Jul 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    How to scan using hp j4580. Booklet only tells how to fax!!!!
    1. Open HP Solution Center with one of the following methods:
      • Click the Windows icon c01319360.gif , click All Programs , click the HP folder, and then click HP Solution Center.
    2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
    3. Use one of the following methods to start the scan:
      • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
      • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
      A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
      2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
      3. Start the scan again.
    4. Read through the various options for the scan settings. Make selections for at least the following items:
      • Scan to: Select your scan destination from the drop-down list.
      • File Type: Select the file type from the drop-down list.
      • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
      • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Important : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
    5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
    Jul 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
    When opening the kodak home center got an error.
    it is a scanning error............ scanning usually take 1-2 minutes to scana document. make sure dat u've proper ink in ur cartridges. contact kodak@ 1800 21 6699 for further issues.
    Jul 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Kodak esp-3 unable to scan from home center,but able to print
    If you are getting a 1-2036 error then there maybe an conflict between the Kodak TWAIN driver and another TWAIN device, most of the time it is with a flat bed scanner. If you have another All in One printer or scanner connected unplug it and uninstall its drivers. If the issue continues uninstall the Kodak software and unhook the kodak printer. Then download the kodak clear utility from HERE
    After the utility runs and you restart your computer Re-install the Kodak Printer software and select WEB install to get the latest version.
    Hopefully that will solve your Home Center scanning issue.
    Jul 13, 2009 | Office Equipment & Supplies
    Bandings on Scaned Images.
    Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. perhaps problem with scanner drivers of the printer. Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals. all the best.
    Jun 13, 2009 | Kodak ESP 5 Printer
    My kodak easy share 5300 all in one printer will not scan
    are getting any error msg like 1-2036 or anyother and are you using Vista or Xp,,,,try using the windows fax and scan settings....let me know and i will try and help you
    Apr 04, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    On a kodak 5100 printer how do I scan a document to the computer to use ss an attachment for E Mail?
    Thank you for allowing me to assist you in this question. Below is some basic information on how to scan with this printer. The Kodak Home Center software will save the file into a directory into your computer and you can use your email program to attach that file into your emails.
    To scan to a file
    1 Set the Default scan destination to File with the Kodak Home Center software.
    2 Place your original face down in the right front corner of the scanner glass.
    3 Press Scan.
    4 Press Start. The original is scanned and saved to a file on your computer according to the scan settings in the Kodak Home Center software.
    To scan to an application
    1 Set the Default scan destination to Application with the Kodak Home Center software.
    3 Press Scan.
    4 Press Start. The original is scanned into Kodak Home Center where you can open it with the application of your choice.
    Mar 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
    Kodak esp 5 won't scan to computer
    Here is the solution I found on the Kodak ESP 5 Support Center web page. Hope it helps or else maybe just visit the web page and browse it to see if you can find the solution to your specific problem.
    Question : How do I scan from my all-in-one printer using MICROSOFT WINDOWS Imaging Acquisition (WIA) Drivers on a computer running WINDOWS VISTA Operating System? Answer : For computers running WINDOWS VISTA Operating System:
    1. Click Start > Programs/All Programs, and select Windows Photo Gallery.
    2. Click Scan at the bottom of the Windows Photo Gallery window, then click New Scan at the top of the window.
    3. Select KODAK ???? AiO (where ???? is the model number) from the Select Device window, then click OK.
    4. Click Preview and make whatever adjustments needed to achieve the desired scan.
    5. When you have made the desired adjustments, click Scan.
      During scanning, the progress is displayed.
      When the scan is complete, the file is displayed in the Windows Fax and Scan window, along with a preview of the file.
    6. Click Save as... to save the file, or click the Print icon to print the file from the Windows Fax and Scan application.
    Feb 28, 2009 | Kodak ESP 5 Printer
    Computers & Internet Logo
    David Payne
    David Payne
