Question about KitchenAid Microwave Ovens
Hello - On my KitchenAide dishwasher model nbr: KUDS01FLSS0 the cancel light blinks constantly and the rinse only light will come on and blink. Also it won't start even when the rinse light comes on. I have turned the power off, I have held down the cancel button for 4 seconds I have replaced one of the boards (buttons) and KitchenAide says they do not have any codes to reset except for turning the power off and holding down the cancel button?
  • kenneth_livi Apr 30, 2010
    There is no programme button??? Is this the control board for my particular model?
  • kenneth_livi May 05, 2010
    I replaced the control assembly. Now the 'Normal' button blinks and the cancel button.???
    Guru:
  • 1,049 Answers
Specific continuous blinking control panel lights often indicate that the buttons for those functions are 'stuck'. The Rinse Only/Quick Rinse indicator will flash if a key/button without an LED of its own or more than one button is stuck.In such a case replacing the control panel is usually necessary to correct the condition.
But if you see pooling water in the bottom of the dish washer. Make sure the dishwasher was able to drain out. Water backing up into the unit might also cause issues like this. For example, I knew someone that had just installed a new garbage disposer, they hooked the hose back up for the dishwasher drain, but did not remove the plastic plug in the GDU. Since the water couldn't drain it just backed everything up.
There isn't too much else it can be...the dish washer is largely a mechanical device. Very few things will effect the electrical but the control panel itself or flow control sensors.
Posted on May 05, 2010
  • KitchenAid Master
  • 19,396 Answers
Try pressing the programme button 4 times in quick succession. This work on some Kitchenaid.
If that does not work , the most likely is a faulty control board. When there is a different fault, the lights will temporary reset, and panel will restart blinking after starting the cycle.
Before replacing control board, inlet , pump, pressure switch, door and float switch must be tested.
Here the board:Electronic control assembly
Here all parts and diagrams for your model.
To get a technician on site , or to get a quote on repair ring the number listed on the owners manual.You can also get an US technician contact using our directory:Contacts.
You can also use one of the websites listed here to get parts and diagrams:
Where do I find parts and diagrams for my Appliance?
Posted on Apr 30, 2010
  • Ginko
    Ginko Apr 30, 2010
    Hi.
    The control board is for the model number provided.
    The program button trick worked on some kitchenaid dishwashers, where the ordinary reset was holding down the program button.
    If the rep told you that there is no other reset then there is none. You can try pressing four times the clear button, but I do not think this will work.
    The timer board must be replaced after testing all other parts.
How do I stop the dashes on my kenmore microwave oven to stop blinking
some models blink so they keep time that way but if it doesn't change you haven't finished settings
Jan 02, 2015 | Kenmore 1.6 cu. ft. Countertop Microwave -...
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    F5 keeps blinking and stove is beeping
    hello,
    This f 5 code indicate or means that the oven has detected a condition it needsto check.what u need to do to solve this problem is to apply the below step as a guild.
    Press "Cancel" to clear the display and to stop the beeping sound,then try turning the oven off and on again. If you still see the "F," turn offthe power to your oven and wait five minutes before turning it on again. If youhear the beep or see the "F" when you try to bake or broil again,
    If your oven still has the warranty this will be covered under this ok
    Hope this is very helpful for .
    Thanks for using fixya.
    Jul 27, 2011 | Microwave Ovens
    My maytag dishwasher's "clean light"
    If this is a Whirlpool manufactured dishwasher, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat related problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
    http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
    Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
    NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
    In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccurring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
    NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel.
    If you still need assistance, please post back and let me know
    Jul 26, 2011 | Microwave Ovens
    The dishwasher won,t start. The lights are blinking but no water comes in.
    Here is a tip that will help you to find out why water will not come into thedishwasher...
    Dishwasher Trouble No Water entering Dishwasher
    heatman101
    Apr 19, 2011 | Microwave Ovens
    I need to reset my Kenmore Elite dishwasher but i don't know how.
    follow the below instructions:
    Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
    Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
    Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
    Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
    Good luck.
    Jul 14, 2010 | Microwave Ovens
    The "clean" light keeps blinking. It will not allow me to start another cycle or to cancel/drain.
    The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or it can be a simple glitch. The following link explains how you may be able to clear the blinking clean light problem:
    Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
    I have often found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
    If you have any questions, please let me know. I hope this helps you solve your problem.
    Dec 09, 2009 | Microwave Ovens
    GE Spacemaker XL1800 my tenant says that she pushed ''a bunch of buttons'' and now the display says locked and the cancel button doesn't cancel this. also the little timer light in the corner is blinking....
    Sounds like the child lock is on.
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    You can download GE owner's manuals and installation instructions here.
    Need parts? Filters?
    You can find helpful exploded view diagrams and order parts by entering your full model number here.
    Oct 29, 2009 | GE Microwave Ovens
    Microwave Ovens Logo
    Top KitchenAid Microwave Ovens Experts
    William Miller
    William Miller
    Stu Ungar
    Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
