Question about Homelite Garden
I need step by step instruction on how to change my pullchord on a Homelite HLT-16 Classic weedeater
#1 Taper
  • 1041 Answers
SOURCE: starts but when throttled continues to die
You have carburetor problems. You will need to take the carb. off and disassemble. Clean the carb. with carb. cleaner and use a Den Tek Brush, (used for cleaning teeth), for the small portals. Check the small screen in carb. to make sure it isn't clogged. The smallest of particals can cause the carb. problems. Check the gaskets as well. Depending on how old your trimmer is, you may have to buy a carb. kit and replace the Needle valve, appropriate gaskets, diaphragm, and small screen.
Jim
Posted on May 30, 2009
canbruce75
  • 1776 Answers
SOURCE: Gas/oil mixture for my Homelite Trimlite weedeater 25 cc
50:1
Posted on Jul 12, 2009
jimmy nutron
  • 132 Answers
SOURCE: Can't get weedeater spool head loose to change the line.
there is three types of heads push, screw, and snap. The screw type have a big ball looking thing on the bottom that when pressed lets the line out. the snap kind are verry distinctive they slid in and two tongs snap in to place you will be able to see them on the out side. the push head just push in and turn.
Posted on Jul 23, 2009
  • 474 Answers
SOURCE: carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Posted on Dec 25, 2009
Biggdex35
  • 333 Answers
SOURCE: How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Posted on Jul 12, 2010
Correct fuel mixture for homelite zip start weedeater.25cc,ut20785..
50:1 five liters unleaded petrol and 100ml 2 stroke oil
Sep 09, 2014 | Homelite Garden
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Primer does not work
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
Apr 22, 2014 | Homelite Mighty Lite Lawn Trimmer
Model ut21004 homelite gas weedeater want stay
fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
May 30, 2011 | Homelite Mighty Lite Lawn Trimmer
Jul 12, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Need manual for homelite sx-135 weedeater
http://www.homelite.com/service_support/order_parts
Feb 14, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Garden Logo
177 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
