Question about Lexmark C534dn Color Laser Printer
LEXMARK C534 I WANT TO THE LAPTOP TO BE CONNECT TO THE PRINTER WIRELESSLY BUT I NEED THE IP ADDRESS AND I DO NOT HAVE ONE AS IT IS CONNECT DIRECTLY TO THE DESKTOP COMPUTER. THE REPORT I PRINTED FOR THE PRINTER STATES THAT THE NETWORK CARD IS NOT CONNECTED. WHAT DO I DO THAT BOTH THE DESKTOP AND LAPTOP CAN PRINT TO THE C534?
    Sergeant:
  • 166 Answers
The easiest way for you to accomplish this is to go onto the desktop computer, and go to control panel and printers & faxes.
From there right click on the printer icon and go under sharing. Turn the sharing on for this printer.
On the laptop, now surf to the ip address of the desktop. If sharing is on correctly the printer should show up. Double click the printer icon and follow the prompts to setup the printer.
If done properly you will then be able to print to the printer THRU the desktop as long as your network settings on the laptop are set correctly to see the desktop.
Posted on Apr 30, 2010
Lost box and directions on how to set up this printer. Need to find TCIP IP address of this printer to connect wirelessly with laptop
it does not have ethernet adapter according to the specs no no ip address or interface ?.
Do you have the optional bluetooth adapter with the printer. ?
You may be able to connect via bluetooth
http://classroom.synonym.com/make-kodak-printer-wireless-bluetooth-17749.html
http://support.en.kodak.com/app/answers/detail/a_id/1157/selected/true
http://www.amazon.com/Kodak-Wireless-Adapter-Printer-Dock/product-reviews/B0006NMSK6
Oct 13, 2015 | Kodak EASYSHARE 5100 All-In-One Printer
How to connect to lexmark pro 905 wirelessly
First, make sure you connect the Lexmark to your wireless network. Select the tools (wrench icon) from the home screen. Scroll to Network Setup and enter your wireless permissions. If setup is complete and the printer successfully connects - the upper right wireless indicator will turn from orange to green. Then it's a matter of connecting your wireless device. If when setting up a new printer (or "Add Printer") you see the Lexmark in the list, then it's a simple point/click. However you might have to manually enter the IP address of the Lexmark on your device which you can find in the tools, Network Setup TC/IP menu.
Jul 09, 2014 | Lexmark Platinum Pro905 multifunction...
I have just purchased a Dell laptop with Windows 7 home premium installed. I have a Cannon PIXMA MP495 printer, what do I need to do to operate thist printer wirelessly?
If you have a wireless router with a wireless network then -
Configure the IP address your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but at a higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Oct 28, 2012 | Dell Computers & Internet
Dell V510 printer worked fine wirelessly until we got a new Belkin Router
The printer's IP address most likely needs to be changed.
Check the Belkin's IP address range (it maybe 192.168.2.***) and configure the printer's IP address accordingly.
Jul 14, 2012 | Dell AllinOne Multifunctional (v515w)...
I have a desktop which is connect to my router and works perfectly fine. I am running win xp pro. I also have a laptop which i connect wirelessly via the router. The problem is when directly connect to...
The ip address conflict is likely caused by a manual IP address that is entered into the printer that is overlapping with an automatic address that your router is giving out. Either switch your printer to DHCP so it gets an automatic address, or reserve the address in the router's DHCP list or pick a manual address to assign that is outside of the range of the DHCP server. Most router will start at address XXX.XXX.XXX.100 so if you pick an address between 20 and 40 then you should not have any more issues with conflicts.
May 11, 2011 | Xerox Phaser 7750DN Laser Printer
Hi i have a lexmark all in one printer,recently i changed my router and now cant connect the printer wirelessly to the computer!
You will have to reconfigure the printer with the router and then reconfigure the PC. All routers don't have the IP address range. That might be the reason why it isnt working after changing the router. Also, if you were using the printer wirelessly, the SSID (network name) and the wireless security needs to be reconfigured to match your new router. The simplest way to achieve this would be to connect the printer hard wired to the router; uninstall the printer drivers completely from the PC; and run the setup disk again. The setup will walk you through the whole process.
Please get in touch if you need further clarifications.
regards
Sandeep
Oct 27, 2009 | Office Equipment & Supplies
I have a wire less network set up and want to use my lexmark x1270 so i can print wireless but cable is USB and do i need to get a cable to put into my router or??
You can't set it up wirelessly, persay. but you can use a special bluetooth adapter in the "pic bridge" slot on the front. I have seen them on e-bay from £5($8) to £12($17) or so.
Oct 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
Can't connect wirelessly to a lexmark x4850
Try:
  1. write down the MAC address of your Lexmark,
  2. log into the router and reserve an IP address with that MAC
  3. Setup the Wireless parameters (SSID, Encryption to WPA or WPA2 Personal, assign a Pass Phrase you can remember. Then save the config and reset the router.
  4. on the Lexmark console, navigate to wireless settings and configure with the matching parameters as set in step 3.
  5. If the wireless connection is matched and connected, open up Internet Browser and type in the IP address in Step 2
  6. It should have a web-interface allowing you to customize it.
  7. Install the printer with the driver disc but should now look for a Networked option. or simply Add or Change the Port of your existing Printer's Properties.
Jun 15, 2009 | Lexmark X4270 All-In-One InkJet Printer
Wireless Printer communication problem with laptop
Please check IP, use manual IP for laptop and Printer. may AUTO IP cause this issue.
Apr 12, 2017 | Lexmark Office Equipment & Supplies
Lexmark C534dn Color Laser Printer Logo
243 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
