Question about Kodak EASYSHARE Z1485 IS Digital Camera
Changed batteries numerous times. On light goes on, but briefly and nothing moves or happens. I think I got the screen to light up - but didn't have time to see what was on it. Camera is not that old. I was thinking of a reset button, or physically moving the lens!
  • bfoote960 Apr 30, 2010
    It seems to be under warranty - was purchased in Nov of 09.
    Thanks Bob
  • Kodak Master
  • 13,433 Answers
Hey,
Moving the lens yourself will not do much good, if the camera doesn't operate properly, you will be unable to take a picture.
Seems like this one is headed to a repairers bench. Not much we can do about fixing this at home. It is not a battery problem from what you have told me.
you can get a free repair estimate from www.advancecamera.com for example, or look up a local repairer, get a estimate and see if its worth the repair.
Posted on Apr 30, 2010
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
Top portion of screen has black and horizontal/vertical white lines. When I turn it on screen is dark gray and unreadable. When pushed to turn pages, lights up briefly, then goes dark gray again. Worked...
Try to hold the slide key for 15 sec. It will reboot your kindle. If black patch is not gone even after that, It's a hw issue. Screen might require to be changed. If it's in warranty Amazon will do it free. That's what i have heard.
Mar 01, 2011 | Amazon Kindle Wireless Reading Device
I have a Gateway DX-4720-03 when I press the "ON" button it lights up briefly then goes out and computer will not boot. Fans do not come on. nothing happens. (If I press button again immediately nothing...
I would actually lean a little more towards the power supply being the problem. You can either have someone locally test it for you, or you can buy a power supply tester to check it out.
Aug 26, 2010 | Gateway DX4720-03 PC Desktop
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Electrical Issue
Had the same problem. I had to remove battery, take apart the battery terminals, sand them a little, then put it all back together. Make sure the screw on the front of the terminal holding the inner bar in place if very tight. Have had no problem ever sense. Good luck.
Nov 10, 2008 | 2005 Suzuki Boulevard S50
Alarm keeps beeping, reads 0
Try testing it first. Press the test/reset button. If it's operating properly on the display:
"GAS" - and it should beep 3 times. Then a number should appear on the display. It should be arround 200. Then it should beep 4 quick times, then nothing for 5 seconds, then 4 quick beeps that keep repeating. It will then show 3 numbers again for a few seconds. When they're gone it will be done resetting. It should show a flashing red light and a 0 or whatever the reading might be. Try this and let me know what happens. If this fixes the problem please rate as fixed. If not, please don't rate yet. Let me know what's going on and I'll be more than happy to help. Thanks.
Apr 15, 2008 | Kidde Nighthawk Combo Gas/co Detector
Tomtom One screen problem
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 04, 2007 | Tomtom ONE GPS Receiver
Panasonic DMR-ES20
For the remote to work, make sure "video" is selected (instead of "tv"). It's the little button on the remote under the red button at the top that turns on the TV ("TV/Video")
As for the split screen, I've had that happen numerous times (when I lose power or revert to default settings). YOu have to go to Setup, Display, and select 4:3.
I hope I have helped you. I'm having other problems - with the audio. Some channels have no audio (maybe 3 or 4) and 2 channels are in SPANISH!!! (??) Weird that it's not uniform. I even tried reverting to default settings (and got that split screen!), but didn't help. It "jumped" a few times to the input type screen. I'm thinking some chip got fried or something. I've had it almost 2 years, and guess that's the "built-in" obsolescence!! :-)
Sep 26, 2007 | Panasonic DMR-ES20EG DVD Recorder
Kodak EASYSHARE Z1485 IS Digital Camera Logo
49 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
