Question about Apple iPhone 3GS Black (16 GB)
My I Phone wond display desktop and programe features with right brightness, I have tried adjusting this in the settings programme but it makes no difference. n_ndlazilwana@hotmail.com
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Tip
How to make older programmes run on xp.
Find the launch file that you want to run. its normally the main executable programme or shortcut.
right click the icon and select the properties.
click on the compatibility tab and place a check next to the text labeled "run this programm in compatitbility mode,"
select the operating system that the program was designed for.
you may need to adjust the display settings also for this program.
click apply
then restart the programme see how it goes.
if the programme does not work try differnt compatibility modes.
on Dec 01, 2009 | Computers & Internet
Would like to be alerted when I place a call on hold that they are still waiting. How do I programm this?
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool on.
Press the next key 6 times (bottom right arrow) .
The display should saySystem Prgrming.
Press the show key (top right arrow)
The display should say Hunt groups
Press the next key 2 times (bottom right arrow) .
The display should say Featr Settings.
The display should say backgrnd Music
Press the next key 9 times (bottom right arrow) .
The display should say Held Reminder:N Press the Chng soft keyto Y Press the next key (bottom right arrow) The screen should say Remind Delay:60 Press the Chng soft key to change the hold timer to the desired time length.
Press the release key when finished
Oct 15, 2009 | NorStar M7310 Phone
M7208 How do I programme the button for hands free
Programming is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Sep 01, 2009 | NorStar M7208 Corded Phone
How do I programme my buttons and how do set up the phone for hands free use. The phones were moved and the technician set all the phones to the original settings so none of the phones have hands free...
Press the heading key (top left arrow) til the display says TERMINALS & SETS again.
enter in next extension to program.
repeat procedure.
Sep 01, 2009 | Nortel Meridian M7208 Corded Phone
Display problem after water damage
Your phone has an automatic brightness adjustment mechanism. The sensor is located on the top near the earpiece.
Go to settings menu and try increasing the brightness.
Jul 12, 2009 | Nokia 6630 Cellular Phone
What is "OPC"? It comes up and goes away.
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Apr 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Auto Adjust
I have found a way to stop flickering of auto adjust - press the menu key on your monitor -factory reset-menu button-all settings. That has solved my problem and hope it helps you.
Sep 04, 2007 | ASUS VW192S Monitor
Apple iPhone 3GS Black (16 GB) Logo
29 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
