Question about KitchenAid Dishwashers
KitchenAid Dishwasher KUDS220T will not start
This dishwasher has not been used for about a year and when I press the buttons on the control panel nothing happens. I checked the filters, breaker, door latch and everything appears to be fine but the inside is completely dry. Could sitting unused so long have caused a problem?
Thanks,
Karen
aborcass
  • 2651 Answers
SOURCE: Hidden control panel not accessible on dishwasher
no thats correct installeation of machine, its meant to be a "hidden" control. simply open the door, choose your options, press start and close door.
Posted on Feb 28, 2008
SOURCE: Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Posted on Nov 02, 2008
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Posted on Jan 16, 2009
SOURCE: Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Posted on Jun 12, 2009
  • 246 Answers
SOURCE: KITCHENAID DISHWASHER DOOR PANEL
www.applianceart.com has many options for you to choose from. They sell many different panels to put on your dishwasher. If you call them (678-727-4747 x32) they can also send you a metal stainless plate that is easily installed. I think the metal ones are around $99.99 and the other options are $39.99
Posted on Aug 21, 2009
Won't start, green flashing light next to start button. Tightened door screws last week. How do I fix this
KITCHENAID DISHWASHER REBOOT - YouTube
? 4:17
www.youtube.com/watch?v=XJnzzXJcOV4
Sep 17, 2012 - Uploaded by DIYAPPLIANCEREPAIR How to reboot your Kitchenaid, Whirlpool, Kenmore by Whirlpool dishwashers control board. ... Up next. Dishwasher Repair will notstart - Repair & Diagnostc - Kitchenaid - Whirlpool ... Kenmore Elite Dishwasher blinking light Control Board FIX - Duration: 1:37. by ... Dishwasher Buttons Not Working?
Oct 19, 2015 | KitchenAid 24 in. KUDP02CR Built-in...
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
On kitchen aid dishwasher, control lock is blinking and preventing the use of any other execute buttons. Can't start a wash .
Which model KitchenAid dishwasher do you have? On some models, the Control Lock can be toggled on/off by holding the Energy Saver Dry touch pad for at least 4 seconds or until the Control Lock light turns on or off.
On another model, the touch pad to press and hold is the 4 Hour Delay button. (On that model, you press and hold for 3+ seconds.) There is often a very tiny label below or on the touchpad indicating which key controls the Control Lock.
If you haven't held the button for long enough, pressing the other touch pads will lead to the Control Lock light blinking 3 times if the Control Lock is active.
If the press and hold method still doesn't work after several attempts, then you may have a problem with the control panel. The dishwasher may need repair.
I hope this helps. Please add a comment with the model number so that I can check if a different touch pad key is the correct one for the Control Lock.
(the Control Lock feature keeps the dishwasher settings from being changed accidently or the unit started when it isn't needed. This can stop a child from resetting the dishwasher or the unit being started while you clean it.)
Oct 15, 2012 | Dishwashers
Start button not activating my kitchenaid sculptura dishwasher
Yes the control panel (also called switch panel) can be replaced.
Refer this site for details. You are probably referring to item 3 in the diagram.
Oct 30, 2011 | KitchenAid KUDS24SE Built-in Dishwasher
Kitchenaid dishwasher Kudio1il 24'stainless steel. Problem with control panel. Dishwasher will not start. Only NORMAL button, HI-Temp button, Energy Saver Dry button, and cancel button light up when...
I'm having similar problem.I uploaded video of my attempt to reset and problem that I have after.I've already tried replacing my board... but have the same problem. The board was a refurb... so not sure if the board sent was defective - or if the problem is the control panel or something else?? thoughts?https://www.box.com/shared/ef486b70331cd4462ed6
Oct 05, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Dishwasher won't work
i think they been charging you for the control panel and replacing the fuse there is a fuse in the control panel go to appliance parts store and tell them you need control panel fuse for your model get two or three then remove the panel and replace the fuse
Sep 07, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
KUDIO1ILBS2 KitchenAid Dishwasher, two years old, not heavy usage: control panel is dead, no other power problems in the apartment, the apartment's electical box shows all breakers ok.
These dishwasher have a thermal fuse near the contol panel protecting the heat sensitive computer. Do you use the Sanitize or Anti-bacteria cycles?? If so then these cycles get very hot and could have made the fuse blow. Kitchenaid also had some loose connection problems at the fuse making the fuse heat up due to the electicity and not actual temperature. The new fuse comes as a kit with connectors already attached to the fuse (dont mess with them) and a junction block to splice the wires.
Jan 18, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Dishwasher lights are all flashing
If you do have the Touch Control Electronic Pad, then you do have a problem, moisture related. You need to open the panel, use a Hairdryer to dry the panel properly and replace. This sorts many of these Touch Control Electronic Pad.
Nov 23, 2007 | KitchenAid 24 in. KUDI02IR Built-in...
Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Jun 13, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
116 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
