Question about Intel D845GVSR Motherboard
Device Driver I want to design a USB Device Driver for DOS using Turbo C.
Ghfjv
Posted on Mar 29, 2008
SOURCE:
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
Plug magicjack usb
If you have a magic jack + your best to connect via Ethernet , the reason for this is because you don`t have the delay a computer imposes. the reason your device dos not work on your routers usb port is the port dos not have the driver software or the operating program magic jack uses to interface with a computer and there is no way to to load it up on your router.
It will not work for you, the usb connection is for comunity access to a had drive on your network only ,,,as far as i know.
Oct 12, 2013 | TP-LINK Computers & Internet
I'am using an amd sempron processor and my turbo c++ program is not being supported can you please help me?it create an error as input not being supported.
may be you are not proper install c++ software
after unzipping files you go to bin folder and send exe to desktop who is near ms dos exe .turbo c++ compiler support all mother boards .because turbo c++ has dos e environment and bios has also dos sported.
Aug 18, 2011 | ASUS M2N-MX Motherboard
\What is the biggest usb drive that works with dos
These questions are more complicated than they sound. A good explanation of how a USB 1.1 device driver will work with DOS: (please carefully consider the caveats and other potential problems as described in this article)
http://www.pocketech.net/support_ts_dos.html
Kudos to Allan Whitehead for coming up with this!
Dec 11, 2009 | Computers & Internet
Bios no option to Boot from usb Cd rom broken
Floppy works right? So you need to boot from floppy disk, install USB drivers in DOS and then access an external USB device... whew. OK, so getting a dos 6.22 boot disk is easy, then you have to load a DOS-level USB device driver that 'recognizes the chipset in your USB controller/port and can turn it 'ON'
Go here and READ ;-) They have everything you need (except for my expert help)
http://www.bootdisk.com/usb.htm
P.S. There are many DOS-level drivers out there, if you don't find one for your PC, make a noise and I'll see if I can help
Feb 23, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
Armada E500
using edlin you can enter for config sys device=c:\dos\himem.sys device=c:\dos\emm386.exe noems device=c:\dos\cdrom.sys /d:mscd001 /l:e for autoexec bat @c:\dos\mscdex.exe /d:mscd001 ----------------------------------- config sys himem.sys is the upper memory manager emm386.exe is the 'gate' to allow access or combine all of it noems turns off expanded memory cdrom.sys is the CD Driver - yours may have a different name /d:mscd001 refers to the name of the CD Rom Drive (generic) /l:e refers to the drive letter (e:) to designate for the CD Hope that helps If used, rate me
Nov 11, 2006 | Compaq Armada E500 Notebook
Intel D845GVSR Motherboard Logo
26 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
