Question about Moen 87555C Trianna Single Handle Pulldown Kitchen Faucet with Soap Dispens...
When we turn on the hot water on our Moen pullout kitchen faucet, it makes a horrible noise. And it is not air in the line - we have checked that out. What can we do?
  • 349 Answers
Pressure change may need a water hammer on hot side.
Posted on May 03, 2010
Recently purchased a new Moen (Renzo pullout)kitchen faucet.The cold water pressure is fine, but the hot water flow seems to be restricted.
This might sound foolish but I have seen it many times. Go under the sink and make sure you hot water bib is turned on to full position. There is very little that will cause restriction in one side verses the other on a new fixture.
Semper Fi,
Z
Jan 29, 2018 | Moen Plumbing
Just removed an old Moen one handle pullout kitchen faucet and installed a brand new updated version. Unable to get hot water line to work properly.
some new faucets come with there on supply lines when you tighten one will twist at the top near the faucet look under the sink to see if this has happened. i've had it happen not long ago
Apr 04, 2016 | Moen Plumbing
Water line
As a rule of thumb the water line to the right is the cold water line.
Apr 19, 2014 | Delta B4310LF-SS-SDISP Foundations Core-B...
Had new water heater installed. Ever since, there is very little water flow from both hot and cold faucets of both (dual) sinks in 2nd floor bathroom. Faucets are Moen 9000 M-PACT type. Could air be t
check the aerators on the faucets. i know after i change a hot water tank there is always some crud that comes through the lines and gets stuck in the aerators, they are the part that holds the screens in place on the spouts.
Aug 14, 2012 | Moen Plumbing
My moen single lever faucet problem is no hot water. The water is warm at most and when you turn it off and on it goes to cold. The faucet is only 8 months old. The only way to get real hot water is to...
The hot side sounds like it has some junk in the hot side blocking the hot water from coming through check hot water line to make sure that it is coming through down below and if so you would need to take it apart and try to get the junk out of that side of the faucet.
Nov 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
Sep 06, 2010 | Delta Model 470: Signature Kitchen...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
Hot water on cold side when first turned on moen 7600 series
did you replace the faucet cartridge??
if you did, you need to take it out and turn it 180 degree (not head to toe). the water control is on reverse.
Nov 16, 2008 | Moen 7437 Chateau Single Hole Kitchen...
Moen 87555C Trianna Single Handle Pulldown Kitchen Faucet with Soap Dispens... Logo
281 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
