Question about Microwave Ovens
Microwave won't heat
GE microwave JVM1451BA All functions work except microwave heating.
  • 185 Answers
Its probally your magnaton
Posted on Mar 25, 2008
6ya staff
SOURCE:
GE Spacemaker XL1800 not working?
  • Open internal fuse
  • Magnetron failure
  • Faulty door interlock
  • Faulty control board
Feb 05, 2018 | GE Microwave Ovens
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have a G.E. microwave that is 2 years old that won't heat up
most likely there is a problem with the magnetron or the thermal device connected to the magnetron...this is located behind the control panel ... if all the functions are working except heat most likely the magnetron has failed.... good luck to you
Jan 13, 2011 | GE JES735WJ Microwave Oven
Microwave display flashing & beeping.
You have a failed membrane keypad.
On this model, GE doesn't make any parts available except the tray and the roller.
If it's in warranty, they will exchange or repair it.
It it's out of warranty, you're out of luck.
I'd advise you to contact GE Customer Service in case they may be able to help you.
Jul 25, 2010 | GE JES1036PWF 1100 Watts Microwave Oven
Runs normal but no longer heats anything. model # JVM1451BA 001 serial # RT9227675
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Oct 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No heat coming from Microwave oven-GE Spacemaker Model XL 1800
in the microwave there is a part which produses the heat which will be called as magnetron you check that part.
Aug 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Jan 24, 2009 | GE JE1540 Microwave Oven
Microwave stopped heating
The magnatron capaciter is burnt out (this is what heats the food!) it can be replaced but it may be cheaper to buy a new oneYjis should fix ya!
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
