Question about OEM Systems PIXMA iP3300 Photo Printer
IP3300 doesnt recognise the inkcartridges-service error 6502
After i installed a new (black) inkcartridge in IP3300 canon printer, it does not want to print anymore.
Message is displayed: "some of the inkcartridges can not be displayed - service error 6502"
the green power button is flashing and alternating with the orange button flahing( the only other button on the printer).
First i thought it was because of the inkcartridge, but another new one did not fix the problem.
  • OEM Systems Master
  • 3,187 Answers
Could you please confirm that all the stick stuff is off the chip on the cartridge, and check the pins on the printer side were the cartridge fits is clean.
Posted on Jun 30, 2017
  • 390 Answers
SOURCE: Canon PIXMA iP3300 Won't Work!
My first suggection is to return it to the store for a full replacement with you original receipt. No way should a printer do this just out of its box. The more you fiddle with it, the less likely to be able to replace it (and the longer you leave it to. If you leave it too long, you will have to have it repaired under warranty. You can try uninstalling it by following correct pc directions at remove programs menu. Then, unplug it after turing it off. Replug it, reinstall it. Try printing now. If still no good, repeat the whole process but this time, do not reinstall with original disc. Make a copy and reinstall the printer with the copy. Noe try printing again. If no luck, return it to store in as original condition as you can manage with all softwares and mauals and your receipt and demand a replacement, Under fair trading they cannot refuse.
Posted on Sep 01, 2007
SOURCE: canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Posted on Jun 16, 2008
SOURCE: printer does not print error mes. unable to clean
noavatar_s.gif Jnar
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
ok el error 46 o unable to clean en las impresoras brother se debe a que llegaste al numero maximo de purgas de cartuchos por lo cual la impresora supone que el wasteink o el deposito donde tira la tinta esta lleno y para evitar que se tire y te haga un desorden monumental recomienda que lo cambies asi por lo cual se sugiere que si no quieres comprar uno nuevo abre la impresora y cambia la esponja.
cuando el contador de limpieza llega a 6400 se genera un error interno machine error 46. asi que las futuras operaciones de limpieza son prohibidas and la impresora no se puede usar
Pero no te espantes ya que tiene arreglo.
Como Reseteando ese famoso contador
como ok
no te voy a complicar
primero daz click en menu/set
y presionas *2864
pero ojo ojo esto lo tienes que hacer todo en menos de 2 segundos
como sabras si funciono si funciono al menos en este modelo mfc 210c empiezan a parparear los botones photo capture copy fax y scan
eso es que si funciono si no funciono presiona stop y vuelve a empezar recuerda menos de 2 segundos
y en la pantalla dira maintenance
ahora el codigo para mantenimiento es 80 presionas 8 y seguido el 0
dira la hora y al final ok
ahora presiona el boton black start son segun las conte como 24 veces te va diciendo datos de la impresora el que nos interesa dice purge:06400
ya estando ahi metemos el codigo 2783 y se pone en 0
ahora presionas el boton stop para regresar al menu anterior dira maintenance y ahi presionas 9 una o dos veces dira please wait hace un reinicio prende y lista para usarse nuevamente
posteado por SYSTEC DURANGO
soporte@tododurango.com email/msn
www.tododurango.com/soporte
This was posted for the MFC 210, but also worked for the Brother MFC3240C. The only difference being the # listed in the purge: being 10000+, but the 2783 and all other instructions remain the same.
Posted on Oct 06, 2008
dante777
  • 623 Answers
SOURCE: Can't find my manual - need to change ink
You can find a description of how to change ink cartridges here.
If you don't have a manual, you can download it from here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Jul 04, 2009
tbirdfan1
  • 3051 Answers
SOURCE: The Brother MFC -210 does not see the cyan inkcartridge.
HELLO THERE
can u tell me if these are the right cartridges for this unit cause there is a big diference if you use the wrong cartridge if it is youare going to haveto go to the maintanence section and reset the cartridge there and than go from there ok
best regards michael
Posted on Sep 14, 2009
Change oink on canon mg3150
Canon Pixma MG3150: How to set up and install ink cartridges
? 2:09
https://www.youtube.com/watch?v=ASSuJYLA4hM
Feb 27, 2012 - Uploaded by Cartridge Genie
This video demonstrates how to set up a Canon Pixma MG3150printer and ... Canon Pixma MG2150 - How to replace printer inkcartridges ...
Nov 28, 2015 | Canon Office Equipment & Supplies
Printer Canon iP1700 - I have already put the new inkcartridge black & colour but the printer says inkcartridge colour is not installed properly. I have installed so many times but same problem.
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Jan 03, 2011 | Canon PIXMA iP1700 InkJet Photo Printer
Black inkcartridge doesn't show
Since your printer is new, is should be covered under guarantee. Please take it back to your dealer, he should swop it out. Alternatively you can arrange a replacement from Lexmark direct through their website.
Feb 28, 2010 | Lexmark X6675 Pro Colour Wireless...
When it prints black cant hardly see,if i print a color and black and white you cant see black print
Common error for Printhead that some colors on your printout are missing.
1. Clean printhead twice press menu button> select clean printhead> select basic/deep clean
2. Test Print Press photo and copy button at the same time for atleast 10 sec. or until it prints
3. Reseat the printhead Simple remove the inkcartridges and the printhead close the printer access door without the printhead. Open the printer access door put the printhead and the inkcartridges back. Then close the printer access door. DO TEST PRINT if still missing colors
4. Replace printhead Contact Kodak AiO support line at 1 800 421 6699
Nov 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HELLO THERE
Sep 14, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA iP4000 has five cartridges 6BLK,e3BLK,6y,6m,6c
You may want to puschace and use a cleaning cartridge but positive results are not guaranteed. It depend how bad your print head is clogged.
The cost is about $5.
Google it (canon printer cleaning cartridge)
Nov 26, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Defective Ink Cartridges for Canon PIXMA MP830
1. Just open and close the cover a bid, this will initiate new checking of all ink cartridges
2. clean the contacts of the inkcartridge chip e.g. with spirit
3. Press the reset/stop-button for >10s to quit the error ... but be aware that the ink level will no longer shon correctly
Jan 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cengiz
could you replace the inkcartridge, it might be that the the black inkcartridge is the problem itself...
Dec 06, 2007 | HP DesignJet 450c InkJet Printer
Canon iP 3300 printer service error 6502
I hope it will help
Nov 24, 2007 | OEM Systems PIXMA iP3300 Photo Printer
Ink cartridge
No, it's not printer fault. It is a cartridge error. Try to exchange your cartridge with your purchaser.
Sep 23, 2007 | Canon Pixma iP6210D InkJet Photo Printer
OEM Systems PIXMA iP3300 Photo Printer Logo
80 people viewed this question
Top OEM Systems Office Equipment & Supplies Experts
k24674
 Russ Hill
Russ Hill
Are you an OEM Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
