Question about Gaggia Titanium Espresso Machine
The machine screen reads "ventilate". I open the knob of hot water but it doesn't fix it. What should I do?
    President:
  • 1,618 Answers
Press the button to switch from steam to hot water, then push in on button, if that works then the tap rod assembly needs to be replaced, also check the ens of the steam nozzle, male sure it is not blocked.
Posted on May 04, 2010
Hot water ventilate problem for Saeco INCANTO DELUXE Espresso Machine 2 signs at a time "hot water" +"ventilate" "
Place a jug under the milk frother and turn the steam knob to allow hot water to flow.
Ventilate will clear after a short time
Jan 27, 2013 | Saeco INCANTO DELUXE Espresso Machine
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
What does ventilate mean on my Saeco coffee machine. It will not work now.
i had this problem too once. its also could be because you have put hot water in the water tank....i had a family member do that and thats what it said....run cold water through wand and see what happens...
Nov 07, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Led reads "ventilate". What do I do?
Hi
Ventilate means that you need to run water through the system.. Open the knob on the right side of the machine if it a Master 5000, or push the right button and light it up, then open the knob if its a Palazzo.
Aug 02, 2009 | Solis Coffee Makers & Espresso Machines
After I primed the machine the digital read out continues to say ''Need to Prime'' and all else has ceased to work including hot water dispensing.
Try this open the hot water valve, when the display reads ventilate, push in the knob on the valve, if water is then released then the tap rod assembly needs to be replaced.
Jul 25, 2009 | Coffee Makers & Espresso Machines
Saeco royal cappuchino ventilate
Alternatively, try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Jun 30, 2008 | Saeco Royal Professional Espresso Machine
Keep reading "ventilate" on the screen
Running hot water button a few times worked for us
Dec 18, 2007 | Saeco Royal Professional Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
80 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
