Question about Kitchen Ranges
I need the metal panel below the door on an apartment size kitchen stove. Model#--EAK10M00 Serial#--779802-114 8800 watts 20 inches In white
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. I don’t think the model no# that you have written is correct. Please post back with the manufacturers name and correct model no# so that I can assist you further. If you still think the model no# is correct then please check this link for parts.
Thanks
Rylee
Posted on Apr 30, 2010
I hit 350 and start on my range and sparks flew out of both sides and now the oven does not work. The stove works but not the oven. can you tell me how to fix this.
It sounds as if the bake element has failed. They cost around 8 to 20 dollars. You will need to unplug the stove first. (Shutting off the stove breaker is good to do before unplugging the stove as an added precaution). On the back of the stove there is a metal
cover with a couple of 1/4 inch hex screws. remove this cover and unplug the bake
element. Then remove the two hex screws inside the oven and slide out the bake element. The model number is located below the oven door behind the drawer to
purchase a replacement. Hope this helps.
Jul 13, 2011 | Frigidaire Kitchen Ranges
We turned on our oven last night and it heated up to 345, wanted to get to 400, then my wife saw smoke form the right hand front of the inside of the oven. I wanted to check the element, but can't figure...
I am assuming you are referring to a conventional stove. First shut off power to the stove at the breaker panel. (either a 40 or 50 amp breaker). Check to see if the elements come on before proceeding.
Slide out stove and unplug it. Look on the back. There will be a vertical piece of sheet metal with 1 to 3 screws or a large flat panel with several screws (1/4 Inch socket). Remove this panel to reveal the leads to the bake element.
remove the leads. Then remove the two screws inside the stove (1/4 inch socket) to remove element. The model and serial for the stove should be located by sliding the drawer out at the bottom of the stove on the left side.
You will need this number for the correct element. They run about 20 dollars typically. Hope this helps.
Feb 17, 2011 | Microwave Ovens
We have a maytag performa electric stove, probabley about 6 years old, and last time we did the self clean on the oven we had a lot of stains that ran down between the inside and outside door panel. This,...
Can anyone please give me the serial number and product number to a 6 year old Maytag Performa glass top stove?? I just broke the ceramic top and need to replace it but don't have a serial number.
Thanks
Liliana.
Dec 12, 2010 | Maytag PER5710 Performa Electric Kitchen...
Where can I find the make and model number of my Kenmore gas stove?
Usually down where you pull the drawer out below the oven door on a small business card size panel. If not check the back and on older stoves they can be under the top if the top raises up easily for cleaning.
Sep 21, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
Glass top on range is broken.
pull bottom panel out look on stove middle just below oven door
thumbs up
Aug 17, 2009 | GE Spectra JBP78 Electric Kitchen Range
Error message FSEO appear on display of whirlpool stove
Door and switches
do not agree
1. Unplug range or disconnect power.
2. Check wires and connectors from control to door switch, then from door switch to control.
3. If no damage to wires or connectors, replace door switch.
4. Replace all parts and panels before operating.
5. Plug in range or reconnect power.
6. Press Cancel/OFF key. Program and start the CLEAN mode, and observe for 1 minute to ensure that
operation is normal.
7. Go to step 1 and complete checks.
Jan 11, 2009 | Whirlpool RF364 Electric Kitchen Range
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
I have a Maytage MER5775RAW electric stove and need to take the door apart
Try this website..it shows and exploded view and a parts list if you punch in your model number.. http://www.pcappliancerepair.com/model-display.php
Hope that helps...
Aug 22, 2008 | Maytag MER5775Q Electric Kitchen Range
How to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
