Question about Microwave Ovens
Light stays on Model #JE2160 Light will not go off.
  • 45 Answers
There are two latches on your microwave door 1 for cutting power off to the magnatron and 1 for the light, it sounds to me like the 1 for the licht has broke off look on your door and check for break mark in line with the other lug. if not then the switch is broke inside the actual oven.
Posted on Mar 25, 2008
My light stays on when I close the door.
If the light stayed on AND the tray kept spinning around, or a fan kept running, then I would say you have a bad door switch. But if everything else works like it is supposed to, then you probably have a relay on the main control board that is stuck closed (on) or you have a shorted triac on the main board. Since very few technicians troubleshoot down to the component level or repair boards, you are probably looking at a board replacement - a rather expensive proposition to fix a light that is stuck on.
Jun 15, 2016 | Emerson MW8999RD 900 Watt Microwave Oven -...
Trying to change a fuse in ge microwave oven je2160. however, we can't determine how to find the old fuse and remove the cover
THE FUSE IS ON THE RIGHT HAND SIDE OF THE MICOWAVE AS YOU LOOK AT IT JUST AT THE TOP BEHIND THE CLOCK
Dec 25, 2010 | GE JE2160 Microwave Oven
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
Interior light will not go off when door is shut
FixYa is not currently notifying us Experts when Clarification Requests are answered, so please contact me directly with your full model number from the tag on / in the unit so we can help you with free do-it-yourself tips and/or an estimate.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 30, 2009 | GE JE2160 Microwave Oven
GE Microwave JE2160 does not heat
Does it make any noises that it didn't before it failed?? It could be a bad secondary interlock switch, cook relay on the PCB, HV circuit problem or bad magnetron. You need an ohm meter to troubleshoot. If you take the cover off, you MUST short across the High Voltage Capacitor terminals to discharge any possible residual charge to prevent shock hazard.
Sep 11, 2009 | GE JE2160 Microwave Oven
How do I remove the control panel on model JE2160
You need to take the back cover off using a special tork wrench. If you don't have one a thin blade screw driver usually works. after getting the back cover off access is pretty easy to remove the screws from the panel. Make sure to discharge the capacitor before attempting any repairs and unplugged of course.
Jan 12, 2009 | GE JE2160 Microwave Oven
GE JE2160 light turns on when you open the door,but no display
This is probably a problem on the control panel, which we regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
But I'd like to first see the the
"mini-manual" (tech sheet) which should be hidden inside the unit behind the control panel or hidden on the left side behind the grille.
You can scan (at 300 dpi) at least the "schematic diagram" page and e-mail it to me at prototech@usa.net or you can fax it (in "detail" or super fine" mode) toll-free to 866-481-2802.
That way I first can see if anything else you can check might be the problem instead.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Jan 10, 2009 | GE JE2160 Microwave Oven
Light Stays ON Inside - GE JE2160
It may be a stuck relay on or other problem on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
It's possible but not likely that you have a bad door swith or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 30, 2007 | GE JE2160 Microwave Oven
Light Stays ON Inside - JE2160
If it's under warranty, I would contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
If not, then I would suspect a bad door switch or a problem on the control board.
We repair these control panels on a regular basis for customers nationwide with our guaranteed $39.95 service.
Please write back with your brand and model number if you need further help.
Nov 29, 2007 | GE JE1540 Microwave Oven
Microwave Ovens Logo
102 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
