Question about Broderbund American Greetings Creatacard Platinum 8 for PC
I have American Greetings Creatacard select 6 and it quit working on some of my projects not all. I tried to uninstall and reinstall but it will not let me uninstall because of a damaged file. How do i unintstall so i can reinstall?
4 Suggested Answers
  • 187 Answers
SOURCE: cannot connect to online projects in american
You have to make sure that you allow your program to access the internet. By default, the firewall is set to block all of your programs. To make an exception:
Click the Start button, go to Control Panel, click Security, and then click the Windows Firewall.
In the left pane, click "allow a program through Windows Firewall."
You have to have an adminstrator account, and you may be prompted for the password at this point.
Check box next to the American Greetings, and then click OK.
The other problem you can run into is with active x controls. Allow programs you trust to run this code, or you will not have full use.
I hope this helped. If you have time, please let me know if this addressed your problem by rating the solution before you go. Thanks for using fixya!
Posted on Dec 27, 2009
  • 2340 Answers
SOURCE: I just bought Creatacard select
Read this link from FIXYA.
Hope it helps.
Posted on Oct 20, 2010
dleemacc
  • 281 Answers
SOURCE: How do I uninstall American
Hi there, This is very easy.Click on start then click on control panel for X P click on classic view and there will be a bunch of icons.The one you want will be add and remove programs,click on this and all of the programs will be listed.Just click on the one you want to remove and follow the prompts.Vista and Windows 7 are in programs and features but the work the same way. Default will be category view but you can change it by clicking on the list on the left page in the control penal. If you are the only on on this computer you should have administrative privilege because you will need that to do this.Thank You for choosing FixYa. Please re post if you have any questions. addremove.jpg
Windows XP Add or Remove Programs
Posted on Aug 31, 2011
My am greetings creatacard select 6 will not down load, it says it has a erroe or problem, like mark on it. I had to clean my pc and all my old stuff wiped out the program, I need to put back my important...
Go to your control panel from start menu if using any OS other than Windows8. (W8 control panel=settings). At control panel menu, locate "change or uninstall program". Click on this selection and all of your installed programs will appear. Scroll own until "American Greetings Createacard" (or close variation) appears and highlight and click this selection. Now an uninstall option appears either on the same highlighted line or at top. Click uninstall and follow prompts if any appear; clicking "ok" or "yes" if they do. Once this program has uninstalled, you can download it again from the original source and it should operate now as intended.
Apr 14, 2014 | Broderbund American Greetings CreataCard...
Can I load American Greetings CreataCard Paltinum 6 on Windows 7?
Yes, almost all software is backwards compatible, it's when you buy software that requires a more updated OS where you have problems.
Mar 07, 2011 | The Learning Company American Greetings...
My CreataCard Gold 7 program will not open, I get the message "AGCCard cannot determine configuration." I attempt to uninstall and reinstall the Broderbund American Greetings CreataCard Gold 7...
After uninstalling the program, go to start, Search, for files and folders and put *creatacard gold* in the search box using the asterisks on both sides. Bu sure to delete any files that are found involving creatacard gold7. Then restart your computer. It sounds like you are having a configuration problem. Is the operating system you are using listed on the configuration of the Creatacard Gold program as a operating system that this software will work on?
You could try and reinstall and if using windows, try using the the program compatability wizard found in the accessories folder in the programs folder. This might help make the program work properly. Alternatively, you may have to get a another version of creatacard gold if it does not work with your operating system. Broderbund may have a download on their site to help make your software work on you operating system. Not having any additional details about your issue, I cannot be certain.
Let me know if I can assist you furhter. Please include any details possible about the issue so I may be of assistance to you.
Brian
Jan 08, 2011 | Broderbund American Greetings Creatacard...
I have tried several times to uninstall creatacard select 7. I can't uninstall it. I'm desperate. Please tell me what to do.
Go to Program Files in your computer's main-drive and delete the folder for create-a-card. If that doesn't work, or it says access denied, restart windows in safe mode and try it again.
Jan 25, 2010 | Broderbund American Greetings Creatacard...
American Greetings Creatacard Silver 5.0 will not install in vista or windows 7
Easiest way to try to solve that is to do the following. 1. Go to My Computer and find the cd/dvd drive with the install disk in it. 2. Right click and select explore. 3. Find the installation file 4. Right Click and select properties. 5. Select the compatability tab. 6. Under Compatibility mode check the check box for "Run this program in compatibility mode for" 7. In the drop down menu select windows 98
Select the settings and visual theme settings to match the program specs. You may need to repeat this process after the install to allow windows to open the program. Follow the same steps but look for the program file under c:\ program files.
Jan 12, 2010 | Broderbund American Greetings Creatacard...
I have American Greetings CreataCard Platium 7 and would like to uninstall it to put a new one on. My computer said it cannot find the file. Can you please help. I have tried to remove it and it want let...
Hi! There may be a missing file or you didn't load perfectly! check CCleaner software, load it and then head for "uninstall" button and select what do you want to remove it, don't worry and have fine
Dec 22, 2009 | Broderbund American Greetings Creatacard...
I have files of cards I created on another PC and am not able to open them even though this new PC has creatacard 6 loaded
are you making sure that you have selected creatacard 6 as your default program for opening these file extensions? if not, then the default program you are using for graphics will attempt to open it but not be able to. Click on one of the cards and select open with and select creatacard 6 as your default
Dec 12, 2009 | Broderbund American Greetings Creatacard...
When I installed PrintMaster Platinum it caused Microsoft Home Pu
Uninstall Printmaster or right click on file to be opened and select open with, and in the prompt select "always open with..."
Nov 24, 2008 | Broderbund American Greetings Creatacard...
Creatacard Platinmum 6 won't work with Windows Vista.
CreataCard Platinum 6 is designed to be used with Windows 95/98/2000/Me or NT 4 and XP, therefore in order to run it in Vista I'd suggest to run your program using Compatinity Mode --> Go to your Desktop --> Right click on the program icon--> Properties-->Compatibility--> select one of the versions above
Nov 12, 2008 | Broderbund American Greetings Creatacard...
Broderbund American Greetings Creatacard Platinum 8 for PC Logo
144 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
