Question about Toshiba Portege 3110CT (P000278510) Motherboard
Portege 3110 Hi I have a very old copy of dos on my 3110, I am trying to change the operating system but i only have a usb external cd rom drive and win3.11 will not regonize and will not enable my usb port pls help!!
I have a bootdisk whit suport a usb , put this disk in floppy and plug this cdrom in usb , next steep install a fresh copy so windows 2000 , evething works fine .
sendme a email and i send for you a copy image disk and sorry a poor english ok !
oliveiragonzalez@gmail.com
Posted on Apr 06, 2008
Get a copy of windows 2000 on a bootable cd.
When you power up the laptop, hold "c" and it will boot off the cd rom :)
Posted on Aug 21, 2008
I have a old Toshiba Portege 7100that i am trying to boot from a usb hardrive. When i start the computer up it says starting.Then 2 seconds later it says insert system drive and press any button to boot....
this model is too old to boot from a usb version1
maybe you can flash the bios to upgrade usb1 to usb version 2
or, load the ubuntu linux operating system using a CD
Sep 30, 2013 | Toshiba Portege 7100 Notebook
My compaq presario f768wm isnt recognizing my cd/dvd rom. my camera quit working and also it says it can't find my audio output device.
For that problem, Try first replace that internal DVD-rom drive other good internal DVD-rom drive. if not Also Detected or recognize.
Try this second solution. insert external USB type DVD-ROM. if not recognize also, Your operating system Have internal software device data corrupted. You need to reinstall operating System like windows xp, windows 7 (OS) etc.. to fix data Corrupted of operating system device for hardware software.
Please see sample external DVD-rom USB type.
Just let me know if not yet working your Compaq Presario 700 series DVD-rom Drive.
Thanks for using Fixya.
Aug 19, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
I have a Samsung VM8000 the dvd rom does not work is there another way to load an operating system on. I do have an external USB DVD drive. Is there a DOS driver I can down load to use this as I have...
What a lovelly old laptop, I still use one.
The BIOS menu will not allow booting from USB as the USB driver must be installed first and that is run within Windows.
You will need and external DVD rom plugged in through the PCMIA sockets on the left side of the laptop.
There are, from time to time, CD roms from Samsung VM8000 laptops offered for sale on eBay.
You could, of course, remove the 20Gb drive and place it in a caddy, load it as an external drive on another pc then copy the XP disk to a directory. Then replace the drive and try and boot from the rebuilt system you have just put on it.
Hope that helps.
Dec 10, 2010 | Dell Latitude D600 Notebook
Boot win98
I'm assuming that you mean that the computer itself has no CD or no Floppy drive.
If there is no operationg system, and no way to actually install one, then you are out of luck.
There are external CD drives, but these normally run within Windows--although your computer may allow for their use on startup.
If your computer is new enough and you can enable legacy USB, then you could theoretically copy a Win98 install CD to the USB drive and boot from that.
If you have an operating system installed and your network is running, you can share a CD on another computer and run the setup from that computer by copying the files across the network.
Apr 18, 2009 | Toshiba Portege 3110CT (P000278510)...
How to reformat my laptop? I don't have Cd rom, no floppy disc, its notbooting in usb flash drive, i dont have external optical drive. Whatshould I do? Thanks in advanced, acer 340t travelmate
If you could go to Avira and download there rescue disk on the flash drive, plug in the flash drive while the lap is off and start it with flash in.
Then you can run the rescue in dos( dos is before windows starts)
You said you could not because of windows, this rescue will scan
the entire hard drive, and if you have something like a rootkit, virus, trojan, Avira will kill it. Avira is the second best anti-virus software
on the planet.
Tap f8 when you lap starts to bring up the boot menu, and pray
that the flash drive is listed.
Apr 10, 2009 | Acer TravelMate 340T Notebook
Bios no option to Boot from usb Cd rom broken
Floppy works right? So you need to boot from floppy disk, install USB drivers in DOS and then access an external USB device... whew. OK, so getting a dos 6.22 boot disk is easy, then you have to load a DOS-level USB device driver that 'recognizes the chipset in your USB controller/port and can turn it 'ON'
Go here and READ ;-) They have everything you need (except for my expert help)
http://www.bootdisk.com/usb.htm
P.S. There are many DOS-level drivers out there, if you don't find one for your PC, make a noise and I'll see if I can help
Feb 23, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Dell server
1) it may just be a driver issue. look up the control panel / devices. if you see a yellow marker , then the drive is at fault . find the driver and install, then try again.
2) maybe the cdrom is dead , try change to another one.
3) if you dont have spare , plug in an external usb cdrom drive . this way , you can still do the update. many dell laptops use external usb cdrom.
Regards
David Ng
Nov 04, 2008 | Dell PowerEdge 6300 Server
Cant install xp to dell c400 with external cd-rom
This is how I did it, you may or may not have the ability. A basic knowledge of Dos is necessary 1) I used another laptop but you could use an adapter to use the hard drive in a regular computer. 2)boot with a windows 98 boot disk, fdisk it to a fat32 partition, make the hard drive a system boot disk (format /s c:) 3) copy the i386 folder and all its contents from a full or full oem (not branded) disk to the laptop drive, also copy smartdrv and highmem.sys from the floppy (speeds thing up dramatically) and create a config.sys file with device=highmem.sys 4)physically install the hard drive back into the C400, boot to dos run smartdrv.exe, then go to the i386 folder and type winnt.exe (enter) wooo should work. MusslaChooda Pakichooda Nathuram Godse
Oct 22, 2008 | Dell Latitude C400 Notebook
Panasonic Toughbook CF-27
i need help i have a panasonic cf-27 toughbook with a usb cd drive and usb floppy drive ive tried both seperate and with a multi usb connector to boot both but it doesnt find them can anyone help me?
Oct 26, 2007 | Panasonic Toughbook CF-27 Notebook
Open Questions:
Which 5 Things missing your website? 1. Social Media Links Social media has become the foremost popular and best type of communication. With the recent announcement from Facebook that over two Billion individuals log in daily to use their website, it might be ludicrous to not faucet into this medium to achieve out to a wider audience vector-free-social-media-icons By using a simple to use social integration tool, websites will easily add this feature to share a message with their social circle quickly. 2. Clear decision to Action Buttons As shortly as you get a visitor to your website, it needs to be captivated to perform a relevant action. It may be a Call us Now button or a Sign-Up form for a free service trial, asking the user to act instantly. Netflix It should make sure that these buttons have the proper aesthetic attractiveness and appear at the correct time while not annoying the end-user. 3. Responsive web design The use of smartphone and tablets has quickly increased since 2012. Marketers corporations'and corporations'and firms} are currently paying shut attention to the present platform wherever fifty-eight of companies have a core mobile promoting team. responsive In such circumstances, a responsive web design is crucial to developing if businesses want to achieve profitable customers. A mobile-friendly website will permit you to compete together with your competitors and provides your business the boost to remain ahead. 4. Email marketing check-in Email marketing campaign could seem like an obsolete technique to stay up-to-date with your customers, however, of course, it can produce wonders for your business if used properly. email signup Placing an email subscription type will permit you to interrupt through the middle of promoting your services to an audience with revenue generating results. 5. Testimonials Word of mouth advertising is that the most credible means that of promoting your business. a region on your website containing remarks and comments of clients'the purchasers'the shoppers} you've got antecedently served will instantly gain the customer trust. test The client testimonials may be a way of gaining your website visitor trust by exhibiting a decent log of your past performance. confirm to focus on these reviews on your website somewhere close to your services section to realize effective results.
Feb 19, 2018 | Facebook Computers & Internet
See all Toshiba Portege 3110CT (P000278510) Motherboard Questions
Toshiba Portege 3110CT (P000278510) Motherboard Logo
366 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
