Question about AquaBrew TE-1220 Coffee Maker
The ldi light is flashing. What should I do?
My swift ldi is taking a longer crank during start. on scaning at service centre it shows the fault fuel temp sensor.but jumper to battery with another battery it starts smoothly
Get battery tested . May be battery near end of life and not holding charge. If unsealed type check water levels in battery.
Jul 07, 2016 | Cars & Trucks
Every once in a while my 1989 Ford F250 7.5 Ldies when i stop and put it in reverse
check egr value unplug it and plug the vacum line off.if it runs smoother the value is bad.
Sep 23, 2012 | 1989 Ford F 250
I lost the manual to my Zipspin DVD duplicator. Where can I find it online?
your device comes from PDEtechnologies so you can go here to get the manual:
http://www.pdetechnology.com/cd.htm or http://www.pdetechnology.com/spec.htm
if there was a model on you posting it would be easier to find it but you have that information so it should not be that hard, the 2nd link takes you to the PDF's site where you can get all the manuals.
if it works for you don't forget to rate me and leave a comment
thx
May 21, 2010 | Lead Data DVD Duplicator (LDI-RDD8X12HD)...
How can I tell if my LG Dare has water damage? I don't see one of the white or red round dots that people talk about.
In order to check for water damage you need to remove the back cover and battery and check for a square or a dot on the back of the phone, this is called the LDI (liquid damage indicator). If the LDI is white then its not water damage, if its red or pink then the phone does have water damage. If you don't see the LDI it might have been removed by someone or by the water itself, you need to take it to a Verizon store so the can check the internal LDI.
Hope this helps,
joe
Feb 25, 2010 | LG Cell Phone Accessories Bundle for...
Looking for service manual or schematic for the Lexicon Core 32 LDI-12T
Check the link below and save a copy on your computer:
http://www.lexiconpro.com/product_downloads/16/manuals/Studio_HW_SW_lnst_Rev1.pdf
Have a great day!
Sep 28, 2009 | Computers & Internet
I have a sidekick lx 09 and i need to know if it has water damage
remove battery at the back and check for the LDI (liquid damage indicator) is red or white. The LDI will normally be a small label on side at the back of the phone. A red lable will reconfirm that your phone has been liquid damaged. Or you can either go to a store or contact your service provider for them to walk you through it.
Aug 11, 2009 | T-Mobile Danger Sidekick Vehicle Power...
Keypad stopped working
Try powercycling the phone, remove battery then check pn the back of the phone if the LDI (liquid damage indicator) is either white or red; white-not liquid damaged if red-that means phone have been luid damaged. If white; try re-testing phone to see if keypads are now working.. if not, try master resetting phone. After the master reset restart device and re-test if phone is now working or not. If nothing works contact your service provider.
Aug 11, 2009 | Motorola Mobility W490 Cellular Phone
Touch screen not responding
Double check at the back of the phone if the LDI (liquid damage indicator) is white. If it's red; phone has been liquid damaged. If white, try to master reset phone. then powercycle it. Retest if phone works, if not contact your service provider for other options and for more troubleshooting process for your phone, if it needed to be exchanged or not.
Aug 11, 2009 | Motorola Mobility MOTOROKR E6
VicencE Gold Ldies Watch
Try this link - nobody seems to claim to specialise in Vicence but I am sure you can find one to suit. Most jewellers deal with most brands. http://www.yell.com/ucs/UcsSearchAction.do?scrambleSeed=33030598&keywords=watch+repair+vicence&companyName=&location=LONDON&search=SEARCH&searchType=advance Hope this helps :)
Feb 12, 2007 | Vicence Rectangular Watch
Do I connect to the high or the low input
someones stereos...?ldies....dont have pin jacks(low impedance)..if you stereo have it make this conection because is more eficient and have low distortion.....good loock.
Jan 13, 2007 | Boss AVA-1404 7-Band Car Equalizer
AquaBrew TE-1220 Coffee Maker Logo
101 people viewed this question
Top AquaBrew Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you an AquaBrew Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
