Question about Fisher Price Power Wheels Little People Toddler School Bus
Where can I get a triangle head screwdriver to fit the screws on the little people bus? Mine has got sand in and some of teh buttons are now stuck so I need to remove and clean it.
    President:
  • 2,309 Answers
You can try suppliers like snap on or mac tools
Posted on Apr 30, 2010
I want to open my wahl hair dryer and clean it out because it smells like something is burning in it. But it has a three prong screw that I've never seen before. How do you get the casing open?
You purchase a Tri wing screwdriver or alternatively make one by grinding a worn out thin screwdriver into a triangle shape that fits the screw heads.
Aug 18, 2014 | Dryers
My ps3 wireless controller will not work. We have left it charging but the red light on teh font does not light up. I know its not the cable as our second controller charges fine. Its onlly 6 months old...
sound like the battery is disconnected, If you feel confident enough, Take out the 5 screws (there should only be 5 screws if there's a sixth screw behind the sticker its a fake) and get a flat headed screwdriver to pry it open holding it (x, o, square, triangle) buttons facing the ground the battery is the first thing you should see, and the small connector to the right of it just reconnect it. If it,s not that it might be loose wires or need a replacement battery.
WARNING - It is easier said than done. The L1 R1 buttons are fiddly to get back in place after you've took it apart.
Apr 24, 2011 | Sony Wireless Controller for PS3
How do I fix one of the frame support buttons on a Bugaboo Cameleon, as the lefthand button is stuck?
Do you mean the tilt buttons? If so you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a phillips. Here's the process: 1. Behind the white button is a screw. Remove it using the phillips screwdriver. 2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver. 4. You'll now have a black base, a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea. 6.Reassemble and repeat for the other side.
Jan 16, 2011 | Bugaboo Cameleon Jogger
Can you recommend a tool to help remove odd screws. Need to remove cover to fix lever. It currently will not catch.
Most of these screws call for what is referred to as a "spanner" bit. You can find bit sets on eBay if you look under "Security Bit Set." Charges should be about $5-$6 with free shipping.
Jan 02, 2011 | Breville CT75XL 4-Slice Toaster
Can't get cover off Canon S630 printer
goto your nearestelectronics store like radioshack or a hardware store that has a wide selection of tools like sears hardware or home depot or lowes and buy the triangle screwdrivers. i hate proprietary screws, i really do. just make sure you get the right size triangle screwdrivers okies?
Jun 04, 2010 | Office Equipment & Supplies
Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Jan 08, 2009 | Tools & Hardware - Others
Singer sewing machine
First try leaving a few drops of penetrant (PB Blaster or WD-40)on each screw letting it soak in overnight. Then using as short of a screwdriver ,with the best fit to the screw, as you can fit under there put it in the screw head, push down hard and turn the screwdriver with a pliers. This should break them loose.
Jul 23, 2008 | Sewing Machines
Head Phone tip got stuck in where u put in your head phones it sucks please tell me what should i do. I plug in these headphone and then when i un pluged them the tip of the head phone was stuck in there....
I actually managed to fix it myself today with just a plain old screw. Find a screw that fits in what is left of the tip and play with it. It took me 2 minutes! Bring a bit force to the screw and twist it and then pull. It popped out like a soar tooth ;-)
Mar 26, 2007 | Sony NW-E107 MP3 Player
Fisher Price Power Wheels Little People Toddler School Bus Logo
189 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
