Question about Kenmore Washing Machines
Kenmore elite he 4t error codes dl f flashing
Kenmore elite washing maching he 4t error codes dl f flashing
  • 1028 Answers
SOURCE: Kenmore Elite Smartwash HE 4T
door lock issue ck for broken door strike on door broken door lock button on door frame also possible connection at main control under top at rear..if moving wires fixes problem try shimming in place only sure fix would be new control..lock not hard to replace remove spring holding door boot on and roll boot back 2 or 3 screws hold lock to frame remove and pull lock to opening remove wires and replace lock
Posted on Sep 09, 2008
SOURCE: f 14 kenmore elite he 4t quietpak9
I have the same problem
Posted on Sep 22, 2008
SOURCE: kenmore elite he 4t washer
I have the he4t and everytime I wash I get an f02 error. The washer wont drain and spin unless you cancel and restart the washer. What can I do to fix this?
Posted on Oct 17, 2008
  • 56 Answers
SOURCE: Our Kenmore Elite HE 4t is flashing a code F dl
the f stands for fault and dl stands for door lock
Posted on Feb 08, 2010
  • 1382 Answers
SOURCE: Kenmore Elite Smartwash - error code F dL flashes
The reason for "F dl" flash is that if your machine doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely if it's frozen or stiff replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank you !!
Posted on Jun 14, 2010
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
My kenmore elite HE 4t washing machine will not start. error message dL. It has happen before but I was able to get it started and working for several weeks till now.
'dl' stands for Door Lock (Error). There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 23, 2011 | Kenmore 24032\24036 Top Load Washer
What does code FDL mean? kenmore elite wash maching
You are getting and error code F-DL which means the main control board is sensing that the door is not locking. Most likely a problem with the door lock/latch assembly.
Feb 02, 2010 | Kenmore 45981 Washer
My screen in showing code "dl" and then "f", please help?
The "dl" code is "doorlock" indicating a problem with the door locking mechanism or switch
Apr 19, 2009 | Kenmore Elite HE4 Electric Dryer
I am getting a dl w/an f error
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
-> Door lid is not closed completely due to interference.
-> Wash media buildup is preventing the lock bolt from extending.
-> Machine/motor control detects open door lid switch when attempting to lock.
-> Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 19, 2009 | Kenmore Elite 45986 Front Load Washer
I have an error code on my Kenmoore elite HE 4t, it say dl f or f dl whatever and makes a clicking sound and will not turn on.
possible connection on main control pull top cover control rear rail try moving connectors in middle area of control if works try to shim connector snug other option replace control
Nov 27, 2008 | Washing Machines
Kenmore elite he 4t washer
Feb 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
193 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
