Question about Movincool Classic Plus 26 Air Conditioner
Do the thermistors go bad? How can I tell, the
Movincool classic plus 26
Do the thermistors go bad? How can I tell, the book says should read approximately 10k ohms @ 73 deg f. What is out of range?
    Guru:
  • 415 Answers
Why is my refridgerator not cooling?
unplug thermistor if doesn't cool over nite bad cooling unit of ok bad thermistor
Jun 04, 2014 | Dometic DM2862 Americana Plus Fridge...
Drying time goes from 44 to 6 minutes
Check your vent system first to make sure that it is clean. You most likely have a bad thermistor in the dryer. The thermistor senses heat and humidity and is responsible for telling your dryer when to shut off. It is probably reading out of spec
Feb 07, 2014 | Samsung DV350AGP 7.3 cu. ft. Steam Gas...
Exponential functions logarithm
You're missing a parentheses.
If you mean e^(ln(177/149)/7)*26 then press
2ND [e^x] ( LN ( 1 7 7 / 1 4 9 ) / 7 ) right-arrow * 2 6 ENTER
if you're in the MATHPRINT mode. In the CLASSIC mode press
2ND [e^x] LN 1 7 7 / 1 4 9 ) / 7 ) * 2 6 ENTER
Sep 15, 2013 | Texas Instruments TI-84 Plus Calculator
Pentair Master Temp Heater is not heating and reading 126
Definitely bad thermistor Pentair reps have seen this happen a lot. Lick finger and touch the two contacts where the thermistor plugs in it should fire up if it's a bad thermistor. If you do an ohm reading you'll find that the ohms do not correlate with the temperature that's displayed. I just trouble shot one and I'm getting 51.2 ohms which equates to 10 - 20 degrees Fahrenheit which is obviously not what is being displayed because it's 126 which is a common number that's displayed when a thermistor is not reading properly
Aug 28, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Malfunction code tE
TE error code stands for thermistor error. You have to remove the front panel and ohm out the heating element. If you have continuity most likely it will be fine. There is a thermistor located next to the heating element that will probably need to be replaced. LG's are the only machine besides GE ref's that I have ever seen thermistors go bad on. There is probably an ohm reading you should get through the thermistor but unless you have an analog meter or a fluke most standard digitals wont read into mega-ohms. Removing the front panel is model specific. But i can tell you the spring around the front boot (drum gasket) needs to be removed and there will be some hidden screws at the bottom by the pump where the access panel is located.
Hope this helps _MJ_
Jan 31, 2010 | LG WM-2277HW Front Load Washer
Freezer defrosting at will; refrigerator side uneven temperatures
Sound like it's going into showroom mode that the same problem we had, by unplugging it for awhile and then plugging it back in usually works if not this what we were told.
Sounds like you have bad thermistors ( # 4 and/or # 5 ) .To access these parts , you will have to remove the inside rear wall of the freezer . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also
Nov 25, 2009 | GE Adora DSS25KSTSS Stainless Steel Side...
My air conditioner is leaking water
The air conditioner have water runs into the plastic container and when the container is full of water the weight will switch off the whole unit until you empty this container.
The tube that deliever the water into this plastic container blocked up with dirt that stop the water runs into the container and overfill the condenser drain pan that water runs all over the floor. Clean this condenser pan outlet and the connecting tube then you will be ok.
Jul 01, 2009 | Movincool Classic Plus 26 Air Conditioner
My movincool 36 won't work - Stuck in HP Fail
I had this problem just this week, to fix it:
To RESET press FAN HI/LO and COOL ON/OFF buttons simultaneously for 3 seconds, controller returns to normal operation.
You can go to the movincool website and register for free. They have manuals and other things you may need.
Jun 30, 2009 | Movincool Office Pro 36 Portable Air...
Can Movincool classic plus 26 AC set the air temperature at below 70 degree F?
aircons normally pull down to approx. 17 degree celcius.and heats to approx 30 degree celcius.  most of the time you need to simply clean the condenser properly and to make sure fans are in good order.
Oct 16, 2007 | Movincool Classic Plus 26 Air Conditioner
Movincool Classic Plus 26 Air Conditioner Logo
541 people viewed this question
Top Movincool Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Movincool Heating and Cooling Expert? Answer questions, earn points and help others
