Question about Panasonic Toughbook 72 Notebook
My toughbook is not start
When i swicth on my toughbook nothing happened . indicator lights steady. the MP have steady light green . hard disk only light a few minutes.
pls help. thanx........
  • Anonymous Jul 28, 2008
    MP indicator lights up and power indicator. Hard drive doesn't light up at all and screen is black.
  • Yossef Benoliel
    Yossef Benoliel Apr 28, 2009
    i have the sane exact problem and cant figure out what to do can you help me please it been 2 weeks i have taken the whole unit apart and put back together!! maybe the batteries but i doubt it!!?
  • 37 Answers
Even if there was any problem with your memory ram, the system should load the BIOS & u could have acces to its settings!
So,there must be some problem with your bios cihp from which the system loads the BIOS environment. You should get that checked.
Posted on May 10, 2008
    Sergeant:
    Champion:
  • 277 Answers
Check your memory ram
Posted on Mar 25, 2008
2 Suggested Answers
  • 10406 Answers
SOURCE: Toughbook will not start, we have it plugged
> battery light turns RED
For Panasonic computers, that indicates that the battery is almost completely discharged (it's YELLOW while charging, and GREEN while fully-charged).
So, my guess is that your AC adapter has failed,
and that your battery needs recharging.
Or, the socket where the AC adapter connects into your computer is damaged, such that no power from the AC adapter is reaching the computer.
Take a "MultiMeter" and check the voltage & amperage output-level from your AC charger. If "zero", go onto eBay and search on the part-number, to find a compatible replacement part.
Posted on Oct 11, 2010
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
Swapped out hdd cf-52 nothing happening
When you swapped out the Hard Disk Drive
of the Panasonic Toughbook CF52 it is very
importatnt that you did not "hot" swap the HDD
but that you turned off the unit with a full shutdown
and unplugged it as well.
Once you removed the Hard Disk Drive (HDD)
I am assuming that you replaced the drive with
another drive that had a proper operating system
already installed. If not, then of course nothing
happened since you replaced the HDD with a blank
or unformatted HDD.
One way to verify if the replacement Hard Drive
is recognized by the Toughbook is to go into
the BIOS by pressing the F2 function key and
checking the size or capacity of the replacement
Hard Disk Drive. If it shows the proper value,
then the HDD is recognized at the Hardware Level.
If it shows HDD as None or Zero then the replacement
HDD is NOT recognized and you have to try a different
drive which is functional.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Nov 08, 2013 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
I am reposting this question with more detail in hopes that someone can help me! I have Lenovo Y550 that has been sitting for several months without being used. It was working fine the last time it was...
You may need to remove all the power from the device including the CMOS Battery. As well try using an external display to see if there is any display.
Oct 27, 2013 | Lenovo Y550 Notebook
My Dell Optiplex 620 started rebooting itself every time Windows started up and then it just went dead. I push the 'ON' button on the front of the computer and nothing happens. I have no lights, no fan,...
I would suspect that the power supply has gone bad and has to be replaced. A simple task, really. var fctb_tool=null; function FCTB_Init_b10486e133b24d6ca38e4d39d69b43a1(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_ee2e8b71ff554752b93d52dd01ec84ba(t) { fctb_tool=t; start(fctb_tool); }
Feb 03, 2011 | Dell OptiPlex GX620 PC Desktop
Toughbook will not start, we have it plugged into the wall and when we switch it on the battery light turns red and nothing else happens? Thanks, Brad M.
Oct 11, 2010 | Panasonic Toughbook 28 Notebook
The unit is charged, the charge indicator light is green, and the three lights on the top are lighted and steady but nothing happens. What am I doing wrong?
Press each cycle button and see if it starts up. I don't know if this is new and you just got it, but if so, you may need to remove any straps and retainers blocking the brushes etc.
Feb 17, 2010 | iRobot 4150 Roomba Vacuum
I was on my Panasonic Toughbook CF 73 this morning, I had been using a wireless connection, but I could not get the wireless to work, so I plugged in the adapter and the phone line for dial up, I got...
On all Panasonic Toughbooks the following works.
Please unplug you Toughbook and remove the battery pack.
Then Please do not put the battery pack back in.
Without the battery pack, plug back in the Toughbook.
Try to start the Toughbook, it should work.
If it does not, try to hold down the power button for 12-15 seconds continuously. This should "reset" your Toughbook.
Good Luck.
Richard, Montreal Based Panasonic Authorized Toughbook Dealer since 1989.
Nov 29, 2009 | Panasonic Toughbook CF-73 Notebook
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Intel Motherboard Problem
Hello ezinash ,
replace ur hard disk with a new one and than try
Jul 21, 2008 | Intel Motherboard
Pan. toughbook c-29 light will turn/flash on but hd won't startup or screen
sounds like a capacitor issue with the boards secondary supply side to me, recommend you dis assymble and check capacitors with low esr meter to determine which way to start trouble shooting power delivery issue. Obviously your getting power to the plug but have you LOAD tested the power supply? Try another one to see?
Feb 11, 2008 | Panasonic Toughbook 48 Notebook
Panasonic Toughbook 72 Notebook Logo
315 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
