Question about Denon AVR-1707 Receiver
Can't get the Denon AVR-1707 to switch to zone 2. Had worked in the past, but has now stopped.
  • jdutton401 Apr 30, 2010
    There doesn't appear to be solution that addresses my problem. Also, the microprocessor reset procedure of holding both the A and B speaker buttons down while powering the unit up does not appear to be having any effect either. Still no zone 2.
    Champion:
  • 211 Answers
You can try a master reset.
Press and hold BOTH A and B speaker selectors on the front panel. At the SAME time, Press the Power button on the front panel. The front panel display will flash once every second. When it does, release the buttons. This will reset your receiver to the factory settings. It will now act like it was just connected for the first time. You will need to reprogram your settings but this will reset the microprocessor which controls the receiver, including the speaker relays internally which disconnect when there is a power fault.
Regards,
Gerard
Posted on Apr 30, 2010
    Genius:
  • 1,354 Answers
Hi
chack folowing site i hope you will get your solution if you get your solution please up-date me
http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=U2boTI-j
I have a Denon AVR 1707 reciever. I am trying to connect my dvd player through RGB cables. The sound works just fine when i turn the reciever to dvd but there is no video. I have the component 2 set to dvd...
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
May 25, 2011 | Denon AVR-1707 Receiver
I have a Denon AVR-1707 with a center, 2 front speakers, and surround sound back speakers. When set to FM radio, all speakers work. When set to TV, only one side speaker works. Any ideas? It worked fine...
Follow the sound back to its source. FM is internal so it can't possibly have a cabling issue.
I imagine your TV sound ultimately originates from a cable box which has a nice juicy digital output that the Denon could use. Why route audio through a TV, like the manuals tell you, when you can get it straight to the best audio device without a detour to a TV and its dubious audio electronics?
Apr 17, 2011 | Denon AVR-1707 Receiver
Trying to hook my lg tv to a denon avr-1707 receiver so i can have external speakers
Use the twin phono audio out on tv to twin phono audio in on Denon AVR-1707 this should work absolutely fine as long as your using an analogue input on the tv if HDMI you would need to purchase a Digitial to analogue audio converter. Hope this helps
Jan 31, 2011 | Denon AVR-1707 Receiver
My denon AVR 1707 has flashing red light have disconected all speakers and it still flashes red is there anything else i can do.
Only what you can do is to bring the receiver into repair shop. The receiver has a hardware problem.
You can repair here
Jul 14, 2010 | Denon AVR-1707 Receiver
Where do i plug in the yellow, red and white cables on the Denon avr 1707 for connection to wii
the yellow goes to the tv then you can have your audio run through the receiver for sound or you can plug in the tv audio in.
Oct 24, 2009 | Denon AVR-1707 Receiver
Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Jun 28, 2009 | Denon AVR-2106 Receiver
Denon AVR 883 Audio glitch
More than likely the protector circuit is getting activated... You can't go below 6 ohms on the surround back which means you need 12 ohm or higher speakers for outside (since the two outputs for surround back/zone2 are in parallel). As a simple diagnostic test, disconnect one speaker and see if the sound survives longer than 2 seconds.
Mar 26, 2008 | Denon AVR-883 Receiver
Denon AVR-1707 Receiver Logo
350 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
