Question about Dymo LabelWriter 400 Turbo Thermal Printer
Dymo prints blotchy labels and feeds out many labels after print
Every time I try to print from my dymo lw400 the text comes out in blotches and pieces all scrunched up on the left side of the label. Then the printer feeds out 4 more blank labels that I then have to feed back through.
Is this a software problem or a hardware problem? My computer said that the drivers are all up to date.
    Problem Solver:
  • 14 Answers
Sounds like you have a couple of issues going on...your labels are incompatible or you have an incorrect template selected in the Dymo Software.
Check that the label model matches the template and you are using quality Dymo Labels. Such as the Dymo name brand or the LabelValue brand Dymo labels.
Posted on May 06, 2010
Dymo letratag blotchy print
Generally this is caused by something getting stuck on the print head. You can try a q-tip or a q-tip with pure rubbing alcohol on it and wipe of the print head.
Nov 06, 2013 | Office Equipment & Supplies
Printer will not print and prints more than asked
Make sure you use genuine DYMO labels, not compatible ones. Also, make sure you select the right size in DYMO Label.
You may have to disable bidirectional support: right-click the printer > Printer Properties > Ports > uncheck the option.
^CM
Aug 30, 2012 | Dymo ® LabelWriter® 450 Series PC...
I want to print a label with two lines of print on it. How do I do it?
To create a two-line label 1. Type the text for the first line and press INSERT. 2. Use the arrow keys to select Second Line and press . A multiline symbol is inserted at the end of the first line, but will not print on the label. 3. Type the text for the second line.
Here's the manual, see page 12 - http://www.dymo-label-printers.co.uk/downloads/LetraTAG-LT100H-Manual.pdf
Jul 14, 2011 | Dymo LetraTAG Thermal Label Printer
When typing the print is faded
Dymo LetraTAGs are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the print starts to fade it's time to put new batteries in. When the batteries are running out the text fades first even when the motor is still feeding tape.
Jan 31, 2011 | Dymo LetraTAG Thermal Label Printer
My Dymo Labelwriter 450 turbo feeds out 4 labels each time I print one. The print setting is on one label. The first one prints and the next three are blank. If I try to use the reverse button the printer...
Multiple label feeding usually occurs because the sides of the spool holding the roll are not squeezed tightly together. Make sure there's no gap between the labels and the sides of the spool. If this doesn't help. take out the labels and blow a blast of air into the feed slot. There is a sensor inside the slot on the left that detects the hole in the labels, and maybe it is blocked.
Jan 26, 2011 | Dymo LabelWriter 400 Thermal Printer
My dymo labelmanager 9000 will not print labels, a comment comes up saying label with arrows pointing to the left each time i press the print button. i have tried pressing the bottom feed button...
The fix for this involves opening the unit up. The problem is the infra red LED sensor on the label exit has slightly miss-aligned giving the error. If you unscrew the two sensor boards, re-align and screw them back all will be well.
Hope this helps.
Jan 10, 2011 | Dymo LabelMANAGER 9000 Printer
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
JMC
Aug 12, 2009 | Dymo LabelWriter 330 Thermal Printer
Labels coming out blank
1. Replace the batteries (use only alcalines)
2. See if the tape is correctly inserted.
3. Clean the printer head
4. Replace the tape with a new one.
5. Check the contrast settings
Jul 20, 2009 | Dymo LetraTAG Thermal Label Printer
We just purchased a DYMO 400 label printer and I am trying to set it up so that we can print existing labels to it. We have hundreds of word documents formated to print labels on 8.5x11 label sheets. Each...
Your dymo labelwriter came with an add-in for word. just highlight the addresses you want to print, click the little label printer icon in the toolbar and it'll do the rest
Dec 30, 2008 | Dymo LabelWriter 400 Thermal Printer
CONTINOUS FEED
Use a DYMO Label/Writer Cleaning Card #60622. One should have come with your printer. Just remove the labels, run this cleaning pad through a few times, insert the labels, and print.
Sep 02, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo LabelWriter 400 Turbo Thermal Printer Logo
554 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
